Datasheet MAX965, MAX966, MAX967, MAX968, MAX969, MAX970 (Maxim) - 5
Manufacturer | Maxim |
Description | Single/Dual/Quad, Micropower, Ultra-Low-Voltage, Rail-to-Rail I/O Comparators |
Pages / Page | 15 / 5 — Typical Operating Characteristics (continued). SUPPLY CURRENT PER … |
File Format / Size | PDF / 2.1 Mb |
Typical Operating Characteristics (continued). SUPPLY CURRENT PER COMPARATOR. INPUT OFFSET VOLTAGE. INPUT BIAS CURRENT
MAX965–MAX970 Single/Dual/Quad, Micropower, Ultra-Low-Voltage, Rail-to-Rail I/O Comparators
(VCC = +3.0V, RPULLUP = 100kΩ, VCM = 0V, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT PER COMPARATOR INPUT OFFSET VOLTAGE INPUT BIAS CURRENT vs. OUTPUT TRANSITION FREQUENCY vs. TEMPERATURE vs. TEMPERATURE
4.0 200 4.0 3.8 190 V 3.5 CC = 5.0V 3.6 180 3.0 MAX965/70 TOC13A 3.4 170 MAX965/70-TOC14a MAX965/70-TOC15a 3.2 160 2.5 3.0 V 150 2.0 CC = 5.5V 2.8 140 1.5 2.6 130 1.0 2.4 VCC = 1.6V INPUT OFFSET VOLTAGE (µV) INPUT BIAS CURRENT (pA) 120 VCC = 3.0V 0.5 2.2 110 SUPPLY CURRENT PER COMPARATOR (µA) 2.0 100 0 0.01 0.1 1 10 100 -60 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 OUTPUT TRANSITION FREQUENCY (kHz) TEMPERATURE (°C) TEMPERATURE (°C)
PROGRAMMED HYSTERESIS REFERENCE VOLTAGE REFERENCE VOLTAGE vs. COMMON-MODE VOLTAGE vs. TEMPERATURE vs. SUPPLY VOLTAGE
40 1.2345 1.239 35 VCC = 5V 1.237 1.2340 MAX965/70 TOC16 MAX965/70 TOC6a 30 1.235 MAX965/70-TOC13 25 1.2335 1.233 20 1.231 1.2330 15 1.229 V 10 REFERENCE VOLTAGE (V) CC = 2V REFENCE VOLTAGE (V) 1.227 1.2325 PROGRAMMED HYSTERESIS (mV) 5 VCC = 5.0V VCC = 3V 1.225 VHYST = 22mV (PROGRAMMED) 0 1.2320 1.223 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 -60 -40 -20 0 20 40 60 80 100 1 1.8 2.6 3.4 4.2 5.0 5.8 COMMON-MODE VOLTAGE (V) TEMPERATURE (°C) VCC (V)
REFERENCE VOLTAGE vs. SOURCE CURRENT PROPAGATION DELAY (tPD+) PROPAGATION DELAY (tPD-)
MAX965/70-TOC15 MAX965/70-TOC16b 1.4 VCC = 3V VCC = 3V 1.3 IN+ IN+ 1.2 MAX965/70-TOC18a 50mV/div 50mV/div 1.1 1.0 0.9 OUT REFERENCE VOLTAGE (V) 0.8 OUT 2V/div 2V/div 0.7 0.6 0 100 200 300 400 500 600 700 2µs/div 2µs/div SOURCE CURRENT (µA) www.maximintegrated.com Maxim Integrated │ 5
