Datasheet ADG736 (Analog Devices) - 6
DescriptionCMOS Low Voltage 2.5 Ω Dual SPDT Switch
Pages / Page12 / 6 — ADG736. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN1. 10 …
File Format / SizePDF / 249 Kb
ADG736. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. IN1. 10 D1. S1A. S1B. GND. TOP VIEW. VDD. (Not to Scale). S2A. S2B. IN2
ADG736 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN1 10 D1 S1A S1B GND TOP VIEW VDD (Not to Scale) S2A S2B IN2
ADG736 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS IN1 1 10 D1 S1A 2 ADG736 9 S1B GND 3 TOP VIEW 8 VDD (Not to Scale) S2A 4 7 S2B
002
IN2 5 6 D2
00046- Figure 2. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 IN1 Logic Control Input. 2 S1A Source Terminal. May be an input or output. 3 GND Ground (0 V) Reference. 4 S2A Source Terminal. May be an input or output. 5 IN2 Logic Control Input. 6 D2 Drain Terminal. May be an input or output. 7 S2B Source Terminal. May be an input or output. 8 VDD Most Positive Power Supply Potential. 9 S1B Source Terminal. May be an input or output. 10 D1 Drain Terminal. May be an input or output.
Table 5. Truth Table Logic Switch A Switch B
0 Off On 1 On Off Rev. D | Page 6 of 12 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Outline Dimensions Ordering Guide Automotive Products
