Datasheet MAX9690 (Maxim) - 2
ManufacturerMaxim
DescriptionUltra-Fast ECL-Output Comparator
Pages / Page4 / 2 — Ultra-Fast ECL-Output Comparator. ABSOLUTE MAXIMUM RATINGS. MAX9690. …
File Format / SizePDF / 36 Kb
Ultra-Fast ECL-Output Comparator. ABSOLUTE MAXIMUM RATINGS. MAX9690. ELECTRICAL CHARACTERISTICS. MAX9690C/E. MAX9690M. PARAMETER
Ultra-Fast ECL-Output Comparator ABSOLUTE MAXIMUM RATINGS MAX9690 ELECTRICAL CHARACTERISTICS MAX9690C/E MAX9690M PARAMETER
Supply Voltages...±6V Operating Temperature Ranges Input Voltages..±5V MAX9690C_ A ...0°C to +70°C Differential Input Voltages...±3.5V MAX9690E_ A ..-40°C to +85°C Output Current ..30mA MAX9690MJA ..-55°C to +125°C Continuous Power Dissipation (TA = +70°C) Storage Temperature Range ...-55°C to +150°C Plastic DIP (derate 9.09mW/°C above +70°C)...727mW Lead Temperature (soldering, 10sec) ...+300°C SO (derate 5.88mW/°C above +70°C) ...471mW
MAX9690
CERDIP (derate 8.00mW/°C above +70°C) ...640mW Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
(V+ = +5V, V- = -5.2V, RL = 50Ω, VT = -2V, TA = +25°C, unless otherwise noted.)
MAX9690C/E MAX9690M PARAMETER SYMBOL CONDITIONS UNITS MIN TYP MAX MIN TYP MAX
T -5 5 -5 5 Input Offset Voltage V A = +25°C OS mV TA = TMIN to TMAX (Note 1) -7 7 -8 8 Temperature Coefficient ∆VOS/∆T 10 15 µV/°C TA = +25°C 5 5 Input Offset Current IOS µA TA = TMIN to TMAX 8 12 TA = +25°C 10 20 10 20 Input Bias Current IB µA TA = TMIN to TMAX 30 40 Input Voltage Range VCM (Note 1) -2.5 +2.5 -2.5 +2.5 V Common-Mode CMRR (Note 1) 80 80 dB Rejection Ratio Power-Supply PSRR 60 60 dB Rejection Ratio Input Resistance RIN (Note 1) 60 60 kΩ Input Capacitance CIN 3 3 pF TA = TMIN -1.05 -0.87 -1.16 -0.89 MAX9690C, TA = TMAX -0.89 -0.70 -0.88 -0.69 MAX9690M Logic Output TA = +25°C -0.96 -0.81 -0.96 -0.81 VOH V High Voltage TA = TMIN -1.14 -0.88 MAX9690E TA = TMAX -0.88 -0.70 TA = +25°C -0.96 -0.81 TA = TMIN -1.83 -1.57 -1.82 -1.55 MAX9690C, TA = TMAX -1.89 -1.65 -1.90 -1.65 MAX9690M Logic Output TA = +25°C -1.85 -1.65 -1.85 -1.65 V V Low Voltage OL TA = TMIN -1.90 -1.65 MAX9690E TA = TMAX -1.83 -1.57 TA = +25°C -1.85 -1.65 Positive Supply TA = +25°C 16 22 16 22 mA Current TA = TMIN to TMAX 24 25 Negative Supply TA = +25°C 20 32 20 32 mA Current TA = TMIN to TMAX 36 37
2 _______________________________________________________________________________________
