Datasheet EFM8SB2 (Silicon Labs) - 6
ManufacturerSilicon Labs
DescriptionEFM8 Ultra Low Power Sleepy Bee 8-bit Microcontrollers (MCUs)
Pages / Page55 / 6 — 3.2 Power. Table 3.1. Power Modes. Power Mode. Details. Mode Entry. …
3.2 Power. Table 3.1. Power Modes. Power Mode. Details. Mode Entry. Wake-Up Sources. 3.3 I/O. 3.4 Clocking. silabs.com
3.2 Power Table 3.1 Power Modes Power Mode Details Mode Entry Wake-Up Sources 3.3 I/O 3.4 Clocking silabs.com
EFM8SB2 Data Sheet System Overview
3.2 Power
All internal circuitry draws power from the VDD supply pin. External I/O pins are powered from the VIO supply voltage (or VDD on devi- ces without a separate VIO connection), while most of the internal circuitry is supplied by an on-chip LDO regulator. Control over the device power can be achieved by enabling/disabling individual peripherals as needed. Each analog peripheral can be disabled when not in use and placed in low power mode. Digital peripherals, such as timers and serial buses, have their clocks gated off and draw little power when they are not in use.
Table 3.1. Power Modes Power Mode Details Mode Entry Wake-Up Sources
Normal Core and all peripherals clocked and fully operational — — Idle • Core halted Set IDLE bit in PCON0 Any interrupt • All peripherals clocked and fully operational • Code resumes execution on wake event Suspend • Core and digital peripherals halted 1. Switch SYSCLK to • RTC0 Alarm Event • Internal oscillators disabled HFOSC0 or LPOSC0 • RTC0 Fail Event • Code resumes execution on wake event 2. Set SUSPEND bit in • Port Match Event PMU0CF • Comparator 0 Rising Edge Stop • All internal power nets shut down Set STOP bit in PCON0 Any reset source • Pins retain state • Exit on any reset source Sleep • Most internal power nets shut down 1. Disable unused ana- • RTC0 Alarm Event • Select circuits remain powered log peripherals • RTC0 Fail Event • Pins retain state 2. Set SLEEP bit in • Port Match Event PMU0CF • All RAM and SFRs retain state • Comparator 0 Rising • Code resumes execution on wake event Edge
3.3 I/O
Digital and analog resources are externally available on the device’s multi-purpose I/O pins. Port pins P0.0-P2.6 can be defined as gen- eral-purpose I/O (GPIO), assigned to one of the internal digital resources through the crossbar or dedicated channels, or assigned to an analog function. Port pin P2.7 can be used as GPIO. Additionally, the C2 Interface Data signal (C2D) is shared with P2.7. • Up to 24 multi-functions I/O pins, supporting digital and analog functions. • Flexible priority crossbar decoder for digital peripheral assignment. • Two drive strength settings for each pin. • Two direct-pin interrupt sources with dedicated interrupt vectors (INT0 and INT1). • Up to 16 direct-pin interrupt sources with shared interrupt vector (Port Match).
3.4 Clocking
The CPU core and peripheral subsystem may be clocked by both internal and external oscillator resources. By default, the system clock comes up running from the 20 MHz low power oscillator divided by 8. • Provides clock to core and peripherals. • 20 MHz low power oscillator (LPOSC0), accurate to +/- 10% over supply and temperature corners. • 24.5 MHz internal oscillator (HFOSC0), accurate to +/- 2% over supply and temperature corners. • External RTC 32 kHz crystal. • External RC, C, CMOS, and high-frequency crystal clock options (EXTCLK). • Clock divider with eight settings for flexible clock scaling: Divide the selected clock source by 1, 2, 4, 8, 16, 32, 64, or 128.
silabs.com
| Smart. Connected. Energy-friendly. Rev. 1.2 | 5 Document Outline 1. Feature List 2. Ordering Information 3. System Overview 3.1 Introduction 3.2 Power 3.3 I/O 3.4 Clocking 3.5 Counters/Timers and PWM 3.6 Communications and Other Digital Peripherals 3.7 Analog 3.8 Reset Sources 3.9 Debugging 3.10 Bootloader 4. Electrical Specifications 4.1 Electrical Characteristics 4.1.1 Recommended Operating Conditions 4.1.2 Power Consumption 4.1.3 Reset and Supply Monitor 4.1.4 Flash Memory 4.1.5 Power Management Timing 4.1.6 Internal Oscillators 4.1.7 Crystal Oscillator 4.1.8 External Clock Input 4.1.9 ADC 4.1.10 Voltage References 4.1.11 Temperature Sensor 4.1.12 Comparators 4.1.13 Programmable Current Reference (IREF0) 4.1.14 Port I/O 4.2 Thermal Conditions 4.3 Absolute Maximum Ratings 4.4 Typical Performance Curves 5. Typical Connection Diagrams 5.1 Power 5.2 Debug 5.3 Other Connections 6. Pin Definitions 6.1 EFM8SB2x-QFN32 Pin Definitions 6.2 EFM8SB2x-QFN24 Pin Definitions 6.3 EFM8SB2x-QFP32 Pin Definitions 7. QFN32 Package Specifications 7.1 QFN32 Package Dimensions 7.2 QFN32 PCB Land Pattern 7.3 QFN32 Package Marking 8. QFN24 Package Specifications 8.1 QFN24 Package Dimensions 8.2 QFN24 PCB Land Pattern 8.3 QFN24 Package Marking 9. QFP32 Package Specifications 9.1 QFP32 Package Dimensions 9.2 QFP32 PCB Land Pattern 9.3 QFP32 Package Marking 10. Revision History 10.1 Revision 1.2 10.2 Revision 1.1 Table of Contents
