STLQ015Electrical characteristicsSymbolParameterTest conditionsMin.Typ.Max.Unit Capacitance (see typical performance Output capacitor 0.47 10 µF C characteristics for stability) OUT ESR 0.056 6 Ω 1. Dropout voltage is the input-to-output voltage difference at which the output voltage is 100 mV below its nominal value. This specification does not apply to output voltages below 1.5 V. 2. During shutdown and at no load, P-channel leakage current flowing through the internal resistor divider causes the VOUT rise. 3. Turn-on time is the time measured between the enable input just exceeding VEN high value and the output voltage just reaching 95% of its nominal value. DS6765 - Rev 7page 7/19 Document Outline 1 Block diagram 2 Pin configuration and description 3 Typical application 4 Maximum ratings 5 Electrical characteristics 6 Typical performance characteristics 7 Package information 7.1 SOT23-5L mechanical data 7.2 SOT23-5L packing information 8 Ordering information Revision history Contents List of tables List of figures Disclaimer
