User Manual DEPG0266RWS800F34 (DKE) - 2
Manufacturer | DKE |
Description | EPD Module |
Pages / Page | 33 / 2 — Revision History. Version. Content. Date. Producer |
File Format / Size | PDF / 1.3 Mb |
EPD Module User Manual
Revision History Version Content Date Producer
2.0 New release 2021/08/03 Update: 2.1 3. Mechanical and Optical Specification 11.Reliability Test 2022/1/13 13.Packaging Update: 4.Mechanical Drawing of EPD Module 2.2 5. Input/output Pin Assignment 2022/2/25 11. Reliability Test 13. Packaging DKE CO.,LTD Page 2of33 Document Outline Update: 13. Packaging 1. Over View 2. Features 3. Mechanical and Optical Specification . 4.Mechanical Drawing of EPD Module 5. Input/output Pin Assignment 6. Electrical Characteristics 6.1 Absolute Maximum Rating 6.2 Panel DC Characteristics 6.3 Panel DC Characteristics(Driver IC Internal Re Notes:VGH,VGL,VSH,VSL drop voltage<2V. 6.4 Panel AC Characteristics 6.4.1 MCU Interface Selection 6.4.2 MCU Serial Interface (4-wire SPI) 6.4.3 MCU Serial Interface (3-wire SPI) 6.4.4 Interface Timing 7.Command Table 9. Typical Application Circuit with SPI Interface 10.Typical Operating Sequence 10.1 LUT from OTP Operation Flow 10.2 LUT from OTP Operation Reference Program Code ACTION VALUE/DATA COMMENT POWER ON 3v delay 10ms PIN CONFIG RESE# low Hardware reset delay 200us RESE# high delay 200us Read busy pin Wait for busy low Command 0x12 Software reset Read busy pin Wait for busy low SET VOLTAGE AND LOAD LUT LOAD IMAGE AND UPDATE Command 0x24 5624bytes Load BW image (152/8*296)(BW) Command 0x26 5624bytes Load image (152/8*296) (RED) Command 0x20 Read busy pin Wait for busy low Command 0x10 Data 0X01 Enter deep sleep mode POWER OFF 11. Reliability Test 12. Quality Assurance 12.1 Environment 12.2 Illuminance 12.3 Inspect method 12.4 Display area 12.5 Ghosting test method 12.6 Inspection items and acceptance criteria 12.6.1Electric defect 12.6.2 Visual defect 13.Packaging 14. Handling, Safety, and Environment Requirement
