User Manual DEPG0266RWS800F34 (DKE) - 8
ManufacturerDKE
DescriptionEPD Module
Pages / Page33 / 8 — Note 5-1: This pin (CS#) is the chip select input connecting to the MCU. …
Note 5-1: This pin (CS#) is the chip select input connecting to the MCU. The chip is enabled for MCU
Note 5-1: This pin (CS#) is the chip select input connecting to the MCU The chip is enabled for MCU
EPD Module User Manual
Note 5-1: This pin (CS#) is the chip select input connecting to the MCU. The chip is enabled for MCU communication only when CS# is pulled LOW. Note 5-2: This pin is (D/C#) Data/Command control pin connecting to the MCU in 4-wire SPI mode. When the pin is pulled HIGH, the data at SDA will be interpreted as data. When the pin is pulled LOW, the data at SDA will be interpreted as command. Note 5-3: This pin (RES#) is reset signal input. The Reset is active low. Note 5-4: This pin is Busy state output pin. When Busy is High, the operation of chip should not be interrupted, command should not be sent. The chip would put Busy pin High when -Outputting display waveform -Communicating with digital temperature sensor. Note 5-5: Bus interface selection pin. BS1 State MCU Interface
L 4-lines serial peripheral interface(SPI) - 8 bits SPI H 3- lines serial peripheral interface(SPI) - 9 bits SPI
6. Electrical Characteristics 6.1 Absolute Maximum Rating Parameter Symbol Rating Unit
Logic supply voltage VCI -0.5 to +6.0 V Logic Input voltage VIN -0.5 to VCI +0.5 V Logic Output voltage VOUT -0.5 to VCI +0.5 V Operating Temp range TOPR 0 to +40 ºC. Storage Temp range TSTG -25 to+40 ºC. Optimal Storage Temp TSTGo 23±3 ºC. Optimal Storage Humidity HSTGo 55±10 %RH
Note: 1
Maximum ratings are those values beyond which damages to the device may occur. Functional operation should be restricted to the limits in the Panel DC Characteristics tables. 2
We guarantee the single pixel display quality for 0-35
, but we only guarantee the barcode readable for 35-40
. 3
The storage time is within 10 days for -25
~ 0
or 40
~ 60
. The display screen should be kept white and face up.
DKE CO.,LTD Page 8of33 Document Outline Update: 13. Packaging 1. Over View 2. Features 3. Mechanical and Optical Specification . 4.Mechanical Drawing of EPD Module 5. Input/output Pin Assignment 6. Electrical Characteristics 6.1 Absolute Maximum Rating 6.2 Panel DC Characteristics 6.3 Panel DC Characteristics(Driver IC Internal Re Notes:VGH,VGL,VSH,VSL drop voltage<2V. 6.4 Panel AC Characteristics 6.4.1 MCU Interface Selection 6.4.2 MCU Serial Interface (4-wire SPI) 6.4.3 MCU Serial Interface (3-wire SPI) 6.4.4 Interface Timing 7.Command Table 9. Typical Application Circuit with SPI Interface 10.Typical Operating Sequence 10.1 LUT from OTP Operation Flow 10.2 LUT from OTP Operation Reference Program Code ACTION VALUE/DATA COMMENT POWER ON 3v delay 10ms PIN CONFIG RESE# low Hardware reset delay 200us RESE# high delay 200us Read busy pin Wait for busy low Command 0x12 Software reset Read busy pin Wait for busy low SET VOLTAGE AND LOAD LUT LOAD IMAGE AND UPDATE Command 0x24 5624bytes Load BW image (152/8*296)(BW) Command 0x26 5624bytes Load image (152/8*296) (RED) Command 0x20 Read busy pin Wait for busy low Command 0x10 Data 0X01 Enter deep sleep mode POWER OFF 11. Reliability Test 12. Quality Assurance 12.1 Environment 12.2 Illuminance 12.3 Inspect method 12.4 Display area 12.5 Ghosting test method 12.6 Inspection items and acceptance criteria 12.6.1Electric defect 12.6.2 Visual defect 13.Packaging 14. Handling, Safety, and Environment Requirement
