Datasheet LF155, LF156, LF256, LF257 LF355, LF356, LF357 (Texas Instruments) - 4
Description | LFx5x J FET Input Operational Amplifiers |
Pages / Page | 46 / 4 — LF155, LF156. , LF256,. LF257 LF355, LF356,. LF357. www.ti.com. 6 … |
File Format / Size | PDF / 2.7 Mb |
LF155, LF156. , LF256,. LF257 LF355, LF356,. LF357. www.ti.com. 6 Specifications. 6.1 Absolute Maximum Ratings. MIN. MAX. UNIT
LF155, LF156 , LF256, LF257 LF355, LF356, LF357
SNOSBH0D – MAY 2000 – REVISED NOVEMBER 2015
www.ti.com 6 Specifications 6.1 Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted) (1)(2)(3)
MIN MAX UNIT
LF155x, LF256x, LF356B ±22 Supply voltage V LF35x ±18 LF15x, LF25x, LF356B ±40 Differential input voltage V LF35x ±30 LF15x, LF25x, LF356B ±20 Input voltage(4) V LF35x ±16 Output short circuit duration Continuous — LF15x 150 LMC package LF25x, LF356B, LF35x 115 TJMAX °C P package LF25x, LF356B, LF35x 100 D package LF25x, LF356B, LF35x 100 TO-99 package Soldering (10 sec.) 300 Soldering PDIP package Soldering (10 sec.) 260 information °C (lead temp.) Vapor phase (60 sec.) LF25x, LF356B, LF35x 215 SOIC package Infrared (15 sec.) LF25x, LF356B, LF35x 220 Storage temperature, Tstg −65 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. (2) The maximum power dissipation for these devices must be derated at elevated temperatures and is dictated by TJMAX, θJA, and the ambient temperature, TA. The maximum available power dissipation at any temperature is PD = (TJMAX − TA) / θJA or the 25°C PdMAX, whichever is less. (3) If Military/Aerospace specified devices are required, contact the TI Sales Office/Distributors for availability and specifications. (4) Unless otherwise specified the absolute maximum negative input voltage is equal to the negative power supply voltage.
6.2 ESD Ratings VALUE UNIT
V(ESD) Electrostatic discharge Human body model (HBM), per ANSI/ESDA/JEDEC JS-001(1)(2) ±1000 V (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) 100 pF discharged through 1.5-kΩ resistor
6.3 Recommended Operating Conditions
MIN NOM MAX UNIT
LF15x ±15 VS ±20 LF25x ±15 VS ±20 Supply voltage, VS V LF356B ±15 VS ±20 LF35x ±15 LF15x –55 TA 125 LF25x –25 TA 85 TA °C LF356B 0 TA 70 LF35x 0 TA 70 4 Submit Documentation Feedback Copyright © 2000–2015, Texas Instruments Incorporated LF156 LF256 LF356 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 AC Electrical Characteristics, TA = TJ = 25°C, VS = ±15 V 6.6 DC Electrical Characteristics, TA = TJ = 25°C, VS = ±15 V 6.7 DC Electrical Characteristics 6.8 Power Dissipation Ratings 6.9 Typical Characteristics 6.9.1 Typical DC Performance Characteristics 6.9.2 Typical AC Performance Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Large Differential Input Voltage 7.3.2 Large Common-Mode Input Voltage 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.3 Application Curves 8.3 System Examples 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.1.1 Printed-Circuit-Board Layout For High-Impedance Work 10.2 Layout Example 11 Device and Documentation Support 11.1 Related Links 11.2 Community Resources 11.3 Trademarks 11.4 Electrostatic Discharge Caution 11.5 Glossary 12 Mechanical, Packaging, and Orderable Information
