Datasheet TPV803, TPV809, TPV810 (3PEAK) - 6
Manufacturer | 3PEAK |
Description | Low Voltage Supervisory Circuit |
Pages / Page | 15 / 6 — TPV803/809/810. Low Voltage Supervisory Circuit. Electrical … |
File Format / Size | PDF / 708 Kb |
TPV803/809/810. Low Voltage Supervisory Circuit. Electrical Characteristics. Parameter. Conditions. Min. Typ. Max. Unit
TPV803/809/810 Low Voltage Supervisory Circuit Electrical Characteristics
VCC = 1.53 V to 5.5 V; TA = −40°C to +125°C, unless otherwise noted.
Parameter Conditions Min Typ Max Unit
VCC Operating Voltage Range 1 5.5 V VCC = 1.8 V 2.2 10 μA Supply Current VCC = 5 V 6 25 μA
RESET THRESHOLD VOLTAGE
TPV8xxV VTH 1.51 1.58 1.63 V TPV8xxW VTH 1.62 1.67 1.71 V TPV8xxY VTH 2.12 2.19 2.25 V TPV8xxZ VTH 2.25 2.32 2.38 V TPV8xxR VTH 2.55 2.63 2.70 V TPV8xxS VTH 2.85 2.93 3.00 V TPV8xxT VTH 2.95 3.08 3.15 V TPV8xxM VTH 4.20 4.38 4.5 V TPV8xxL VTH 4.45 4.63 4.75 V RESET THRESHOLD TEMPERATURE 60 ppm/°C COEFFICIENT 2 × RESET THRESHOLD HYSTERESIS mV VTH/1000 VCC TO RESET DELAY VTH − VCC = 100 mV 20 μs RESET TIMEOUT PERIOD 140 200 280 ms RESET OUTPUT VOLTAGE VOL VCC ≥ 1 V, ISINK = 50 μA 0.3 V (Push-Pull and open drain) RESET OUTPUT VOLTAGE VOL VCC = VTH, ISINK = 1.2 mA 0.3 V (Push-Pull and open drain) VTH ≥ 2.63V RESET OUTPUT VOLTAGE VOL VCC = VTH, ISINK = 3.2mA 0.4 V (Push-Pull and open drain) VTH ≥ 4V RESET OUTPUT VOLTAGE VOH 0.8 × VCC ≥ 1.8 V, ISOURCE = 200 μA V (Push-Pull Only) VCC RESET OUTPUT VOLTAGE VOH VCC = VTH, ISOURCE = 500 μA 0.8 × V (Push-Pull Only) VTH ≥ 2.63 V VCC RESET OUTPUT VOLTAGE VOH VCC = VTH, ISOURCE = 800 μA VCC- V (Push-Pull Only) VTH ≥ 4 V 1.5V
www.3peakic.com.cn 6 / 15 Rev.A.5
