Datasheet 1N5400, 1N5401, 1N5402, 1N5404, 1N5406, 1N5407, 1N5408 (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | Axial-Lead Glass Passivated Standard Recovery Rectifiers |
Pages / Page | 7 / 1 — DATA SHEET. www.onsemi.com. STANDARD RECOVERY. RECTIFIERS. 50−1000 VOLTS. … |
File Format / Size | PDF / 156 Kb |
DATA SHEET. www.onsemi.com. STANDARD RECOVERY. RECTIFIERS. 50−1000 VOLTS. 3.0 AMPERES. Features. AXIAL LEAD. CASE 267−05. STYLE 1
link to page 5
DATA SHEET www.onsemi.com
STANDARD RECOVERY
Recovery Rectifiers
RECTIFIERS 50−1000 VOLTS
1N5400 thru 1N5408
3.0 AMPERES
Lead mounted standard recovery rectifiers are designed for use in power supplies and other applications having need of a device with the following features:
Features
• High Current to Small Size
AXIAL LEAD CASE 267−05
• High Surge Current Capability
STYLE 1
• Low Forward Voltage Drop • Void−Free Economical Plastic Package • Available in Volume Quantities
MARKING DIAGRAM
• Plastic Meets UL 94 V−0 for Flammability • These are Pb−Free Devices A 1N 540x
Mechanical Characteristics:
YYWWG • Case: Epoxy, Molded G • Weight: 1.1 Gram (Approximately) • A = Assembly Location Finish: All External Surfaces Corrosion Resistant and Terminal 1N540x = Device Number Leads are Readily Solderable x = 0, 1, 2, 4, 6, 7 or 8 • Lead and Mounting Surface Temperature for Soldering Purposes: YY = Year 260°C Max. for 10 Seconds WW = Work Week G = Pb−Free Package • Polarity: Cathode Indicated by Polarity Band (Note: Microdot may be in either location)
ORDERING INFORMATION
See detailed ordering and shipping information on page 5 of this data sheet. *For additional information on our Pb−Free strategy and soldering details, please download the
onsemi
Soldering and Mounting Techniques Reference Manual, SOLDERRM/D. © Semiconductor Components Industries, LLC, 2008
1
Publication Order Number:
August, 2021 − Rev. 12 1N5400/D
