Emitter Mechanical Dimensions Notes: 1. The Anode side of the device is denoted by a hole in the lead frame. 2. Electrical insulation between the case and the board is required. Do not electrically connect either the anode or cathode to the slug. 3. Drawing not to scale. 4. All dimensions are in millimeters. 5. Unless otherwise indicated, tolerances are ± 0.20mm. 6. Please do not bend the leads of the LED, otherwise it will damage the LED. 7. Please do not use a force of over 3kgf impact or pressure on the lens of the LED, otherwiseit will cause a catastrophic failure. *The appearance and specifications of the product may be modified for improvement without notice. 2 Document Outline 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
