Datasheet LM194, LM394 (National Semiconductor) - 7
ManufacturerNational Semiconductor
DescriptionSupermatch Pair
Pages / Page10 / 7 — Typical. Performance. Characteristics. (Continued). Collector. to. …
File Format / SizePDF / 238 Kb
Typical. Performance. Characteristics. (Continued). Collector. to. Collector. Capacitance. Emitter-Base. Capacitance. vs. Collector-Base
Typical Performance Characteristics (Continued) Collector to Collector Capacitance Emitter-Base Capacitance vs Collector-Base
Typical Performance Characteristics (Continued) Collector to Collector Capacitance Emitter-Base Capacitance vs Collector-Base Capacitance vs vs Collector-Substrate Voltage Reverse Bias Voltage Reverse Bias Voltage Collector-Base Leakage vs Collector to Collector Leakage Offset Voltage Long Term Temperature vs Temperature Stability at High Temperature TL/H/9241 – 9 Emitter-Base Log Conformity TL/H/9241 – 10 Low Frequency Noise of Differential Pair* TL/H/9241 – 11 *Unit must be in still air environment so that differential lead temperature is held to less than 0.0003§C. 7
