Datasheet 2N5911, 2N5912 (Calogic) - 2
Manufacturer | Calogic |
Description | Dual N-Channel JFET High Frequency Amplifier |
Pages / Page | 2 / 2 — 2N5911 / 2N5912. ELECTRICAL CHARACTERISTICS. 2N5911. 2N5912. SYMBOL. … |
File Format / Size | PDF / 37 Kb |
2N5911 / 2N5912. ELECTRICAL CHARACTERISTICS. 2N5911. 2N5912. SYMBOL. PARAMETER. UNITS. TEST CONDITIONS. MIN MAX MIN MAX. NOTE 1:
2N5911 / 2N5912
LLC
(Continued) (TA = 25oC unless otherwise specified)
2N5911 2N5912 SYMBOL PARAMETER UNITS TEST CONDITIONS MIN MAX MIN MAX
| IG1 -IG2 | Differential Gate Current 20 20 nA VDG = 10V, ID = 5mA TA = 125oC IDSS1 V Saturation Drain Current Ratio 0.95 1 0.95 1 DS = 10V, VGS = 0 IDSS2 (Pulsewidth 300µA, duty cycle ≤3%) | VGS1 -VGS2 | Differential Gate-Source Voltage 10 15 mV T 20 40 A = 25oC ∆ | V Gate-Source Voltage GS1 − VGS2 | TB = 125oC Differential Drift (Measured at µV/oC VDG = 10V, ID = 5mA ∆T end points, TA and TB) T 20 40 A = -55oC TB = 25oC gfs1 Transconductance Ratio 0.95 1 0.95 1 f = 1kHz gfs2
NOTE 1:
For design reference only, not 100% tested. CALOGIC LLC, 237 WHITNEY PLACE, FREMONT, CA 94539, 510-656-2900 PHONE, 510-651-1076 FAX DS013 REV B
