Datasheet BAS521 (Diodes) - 2
ManufacturerDiodes
DescriptionHigh Voltage Switching Diode
Pages / Page5 / 2 — BAS521. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal …
File Format / SizePDF / 346 Kb
BAS521. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics. Electrical Characteristics. Min. Max. Test Condition
BAS521 Maximum Ratings Characteristic Symbol Value Unit Thermal Characteristics Electrical Characteristics Min Max Test Condition
(@TA = +25°C, unless otherwise specified.)
Repetitive Peak Reverse Voltage VRRM 300 V Working Peak Reverse Voltage DC Blocking Voltage VRWM 300 V Forward Current (Note 6) IF 250 mA Non-Repetitive Peak Forward Surge Current @ t = 1.0µs IFSM 4.5 A Repetitive Peak Forward Current (Note 6) IFRM 1 A
Thermal Characteristics Characteristic Symbol Value Unit
Power Dissipation (Note 6) PD 325 mW Thermal Resistance Junction to Ambient Air (Note 6) RθJA 385 °C/W Operating and Storage Temperature Range TJ, TSTG -65 to +150 °C
Characteristic Symbol Min Max Unit Test Condition
Reverse Breakdown Voltage (Note 7) V(BR)R 300  V IR = 100µA Forward Voltage VF  1.1 V IF = 100mA  50 nA VR = 5V Reverse Current (Note 7) IR  150 nA VR = 250V  100 µA VR = 250V, TJ = +150°C Total Capacitance CT  5 pF VR = 0, f = 1.0MHz Reverse Recovery Time trr  50 ns IF = IR = 30mA, Irr = 0.1 × IR, RL = 100Ω Notes: 6. Part mounted on FR-4 board with recommended pad layout, which can be found on our website at http://www.diodes.com. 7. Short duration pulse test used to minimize self-heating effect. BAS521 2 of 5 August 2019 Document number: DS32175 Rev. 6 - 2
www.diodes.com
© Diodes Incorporated Document Outline Mechanical Data Features Marking Information Package Outline Dimensions Suggested Pad Layout
