Datasheet TMC828, TMC829 (Microchip) - 3
ManufacturerMicrochip
DescriptionSwitched Capacitor Voltage Converters
Pages / Page26 / 3 — TCM828/TCM829. 1.0. ELECTRICAL. † Notice:. CHARACTERISTICS. Absolute …
File Format / SizePDF / 368 Kb
TCM828/TCM829. 1.0. ELECTRICAL. † Notice:. CHARACTERISTICS. Absolute Maximum Ratings †. TCM828 only
TCM828/TCM829 1.0 ELECTRICAL † Notice: CHARACTERISTICS Absolute Maximum Ratings † TCM828 only
link to page 3
Stresses above those listed under “Maximum
CHARACTERISTICS
Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at those or any other conditions above those
indicated in the operational listings of this specification Input Voltage (V is not implied. Exposure to maximum rating conditions IN to GND) .. +30V for extended periods may affect device reliability. Output Voltage (OUT to GND) ...6.0V, +0.3V Current at OUT Pin .. 50 mA Short-Circuit Duration – OUT to GND ..Indefinite Operating Temperature Range .. -40°C to +85°C Variable Temp. Range (
TCM828 only
) ... ...-40°C to +125°C Power Dissipation (T ≤ A 70°C) .. 240 mW Storage Temperature (Unbiased)..-65°C to +150°C Lead Temperature (Soldering, 10 sec).. +300°C
ELECTRICAL CHARACTERISTICS (0°C TO +85°C) Electrical Specifications:
TA = 0°C to +85°C, VIN = +5V, C1 = C2 = 10 µF (TCM828), C1 = C2 = 3.3 µF (TCM829), unless otherwise noted. Typical values are at TA = +25°C.
Parameters Sym Min Typ Max Units Conditions
Supply Current IDD — 50 90 µA
TCM828,
TA = +25°C — 115 260 µA
TCM829
, TA = +25°C Minimum Supply V+ 1.5 — — V RLOAD = 10 kΩ, Voltage TA = 0°C to +85°C Maximum Supply V+ — — 5.5 V RLOAD = 10 kΩ Voltage Oscillator Frequency FOSC 8.4 12 15.6 kHz
TCM828,
TA = +25°C 24.5 35 45.5 kHz
TCM829
, TA = +25°C Power Efficiency PEFF — 96 — % ILOAD = 3 mA,TA = +25°C Voltage Conversion VEFF 95 99.9 — % RLOAD = ∞ Efficiency Output Resistance ROUT — 25 50 Ω IOUT = 5 mA,TA = +25°C — — 65 Ω IOUT = 5 mA,TA = 0°C to +85°C
Note 1:
Capacitor contribution is approximately 20% of the output impedance [ESR = 1/pump frequency x capacitance)].
ELECTRICAL CHARACTERISTICS (-40°C TO +85°C) Electrical Specifications:
TA = -40°C to +85°C, VIN = +5V, C1 = C2 = 10 µF (TCM828), C1 = C2 = 3.3 µF (TCM829), unless otherwise noted. Typical values are at TA = +25°C.
(Note 1 ) Parameters Sym Min Typ Max Units Conditions
Supply Current IDD — — 115 µA
TCM828
— — 325 µA
TCM829
Supply Voltage Range V+ 1.5 — 5.5 V RLOAD = 10 kΩ Oscillator Frequency FOSC 6 — 15.6 kHz
TCM828
19 — 45.5 kHz
TCM829
Output Resistance ROUT — — 65 Ω IOUT = 5 mA
Note 1:
All -40°C to +85°C specifications above are assured by design. © 2010 Microchip Technology Inc. DS21488B-page 3 Document Outline 1.0 Electrical Characteristics 2.0 Typical Characteristics FIGURE 2-1: Output Resistance vs. Supply Voltage. FIGURE 2-2: Output Resistance vs. Temperature. FIGURE 2-3: TCM828 – Output Current vs. Capacitance. FIGURE 2-4: TCM829 – Output Current vs. Capacitance. FIGURE 2-5: TCM828 – Output Voltage Ripple vs. Capacitance. FIGURE 2-6: TCM829 – Output Voltage Ripple vs. Capacitance. FIGURE 2-7: Supply Current vs. Supply Voltage. FIGURE 2-8: TCM828 – Pump Frequency vs. Temperature. FIGURE 2-9: TCM829 – Pump Frequency vs. Temperature. FIGURE 2-10: Output Voltage vs. Output Current. FIGURE 2-11: Efficiency vs. Output Current. 3.0 Pin Description TABLE 3-1: Pin Function Table 4.0 Detailed Description FIGURE 4-1: Ideal Switched Capacitor Charge Pump. 5.0 APPLICATIONS INFORMATION FIGURE 5-1: Ideal Switched Capacitor Model. FIGURE 5-2: Equivalent Output Resistance. TABLE 5-1: Output Resistance vs. C1 (ESR = 0.1W) TABLE 5-2: Output Voltage Ripple vs. C2 (ESR = 0.1W) IOUT 10mA FIGURE 5-3: Test Circuit. FIGURE 5-4: Cascading TCM828 or TCM829 Devices to Increase Output Voltage. FIGURE 5-5: Paralleling TCM828 or TCM829 Devices to Reduce Output Resistance. FIGURE 5-6: Combined Doubler and Inverter. FIGURE 5-7: High V– Load Current. 6.0 Packaging Information 6.1 Package Marking Information FIGURE 6-1: Component Taping Orientation for 5-Pin SOT-23 (EIAJ SC-74A) Devices. Corporate Office Atlanta Boston Chicago Cleveland Fax: 216-447-0643 Dallas Detroit Kokomo Toronto Fax: 852-2401-3431 Australia - Sydney China - Beijing China - Shanghai India - Bangalore Korea - Daegu Korea - Seoul Singapore Taiwan - Taipei Fax: 43-7242-2244-393 Denmark - Copenhagen France - Paris Germany - Munich Italy - Milan Spain - Madrid UK - Wokingham Worldwide Sales and Service Trademarks Worldwide Sales
