Datasheet PVI (International Rectifier) - 5
ManufacturerInternational Rectifier
DescriptionPhotovoltaic Isolator 5-10 Volt Output
Pages / Page5 / 5 — Application Note:. Case Outline. IR WORLD HEADQUARTERS:
File Format / SizePDF / 119 Kb
Application Note: Case Outline IR WORLD HEADQUARTERS:
Series PVI
Application Note:
The outputs of the PVI1050 (pins 5-6 and 7-8) may be placed in series connection to produce a 10-volt output with a 5µA minimum short circuit current. Alternatively, the two ouptut of the PVI1050 may be connected in paral- lel to produce a 5.0-volt ouput with a 10µA minimum short circuit current. The two outputs of the PVI1050 may be applied separately with a maximum 1200VDC between the outputs. Input-to-output isolation to either output is 2500V (RMS).
Case Outline
(Dimensions in millimeters (inches)) Mechanical Specifications: Package: 8-pin DIP Tolerances: .015 (.38) unless otherwise specified Case Material: molded epoxy Weight: .07 oz. (2 gr.)
233 Kansas St., El Segundo, California 90245 Tel: (310) 252-7105 Data and specifications subject to change without notice. 12/6/2000 5
