Datasheet CMPSH-3, CMPSH-3A, CMPSH-3C, CMPSH-3S (MCC)
ManufacturerMCC
Description350mW 30Volt Switching Diode
Pages / Page3 / 1 — CMPSH-3,CMPSH-3A,CMPSH-3C,CMPSH-3S. Features. 350mW 30Volt. Switching …
File Format / SizePDF / 505 Kb
CMPSH-3,CMPSH-3A,CMPSH-3C,CMPSH-3S. Features. 350mW 30Volt. Switching Diode. Maximum Ratings
Datasheet CMPSH-3, CMPSH-3A, CMPSH-3C, CMPSH-3S MCC
CMPSH-3,CMPSH-3A,CMPSH-3C,CMPSH-3S Features
• Low Current Leakage • For Surface Mount Applications • Halogen Free. "Green" Device (Note 1)
350mW 30Volt
• Moisture Sensitivity Level 1 • Epoxy Meets UL 94 V-0 Flammability Rating
Switching Diode
• Lead Free Finish/RoHS Compliant ("P" Suffix Designates RoHS Compliant. See Ordering Information)
Maximum Ratings
• Operating Junction Temperature Range: -55°C to +150°C • Storage Temperature Range: -55°C to +150°C MCC Device Reverse Voltage SOT-23 Part Number Marking VR A CMPSH-3 D95 30V D CMPSH-3A DB1 30V C B CMPSH-3C DB2 30V CMPSH-3S DA5 30V F E Average Rectified Output Io 100mA G H J Current L Power K P Dissipation TOT 350mW DIMENSIONS
Electrical Characteristics @ 25°C Unless Otherwise Specified
DIM INCHES MM NOTE MIN MAX MIN MAX 0.33V IFM=2.0mA Maximum A 0.110 0.120 2.80 3.04 V 0.45V I Forward Voltage F FM=15.0mA B 0.083 0.104 2.10 2.64 1.00V IFM=100.0mA C 0.047 0.055 1.20 1.40 D 0.034 0.041 0.85 1.05 Maximum E 0.067 0.083 1.70 2.10 500nA VR=25V,Tj=25℃ Reverse voltage I F 0.018 0.024 0.45 0.60 R 100μA V G leakage current R=25V,Tj=100℃ 0.0004 0.006 0.01 0.15 H 0.035 0.043 0.90 1.10 J 0.003 0.007 0.08 0.18 Typical Junction C V K 0.014 0.020 0.35 0.51 R=0.0V,f=1.0MHz Capacitance J 4pF L 0.007 0.020 0.20 0.50 Reverse I
Suggested Solder Pad Layout
t F=10mA, IR=10mA Recovery Time rr 4.0ns I , =100Ω rr=0.1*IR RL 0.031 0.800 Note: 1. Halogen free "Green” products are defined as those which contain <900ppm bromine, 0.035 0.900 <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 0.079 inches 2.000 mm
Internal Structure
0.037 0.950 0.037 0.950 CMPSH-3 CMPSH-3A CMPSH-3C CMPSH-3S Rev.3-2-08012020 1/3 MCCSEMI.COM Document Outline 空白页面
