Datasheet UVCLEAN (SETi) - 4
ManufacturerSETi
DescriptionHigh Power UVCLEAN Lamps (10-15mW)
Pages / Page4 / 4 — Typical**. Typ Peak. Typ. Optical. Window. (If ). Typ. Part Number. …
Typical**. Typ Peak. Typ. Optical. Window. (If ). Typ. Part Number. Wavelength. Tolerance. Package. FWHM. Power. Type. (nm). (±3nm). Pout (μW)
Typical** Typ Peak Typ Optical Window (If ) Typ Part Number Wavelength Tolerance Package FWHM Power Type (nm) (±3nm) Pout (μW)
High Power UVCLEAN ® Lamps (10-15mW)
Typical** Typ Peak Typ. Optical Window (If ) Typ Part Number Wavelength Tolerance Package FWHM Power Type (nm) (±3nm) Pout (μW) If
UVCLEAN255FW-15 255 ±5nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN255HS-15 255 ±5nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN265FW-15 265 ±5nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN265HS-15 265 ±5nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN275FW-15 275 ±5nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN275HS-15 275 ±5nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN280FW-15 280 ±5nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN280HS-15 280 ±5nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN290FW-15 290 ±5nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN290HS-15 290 ±5nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN300FW-15 300 ±5nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN300HS-15 300 ±5nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN315FW-15 315 ±5nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN315HS-15 315 ±5nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN330FW-15 330 ±10nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN330HS-15 330 ±10nm 10-15mW TO-3 Hemispherical 720mA 12 UVCLEAN350FW-15 350 ±10nm 10-15mW TO-3 Flat Window 720mA 12 UVCLEAN350HS-15 350 ±10nm 10-15mW TO-3 Hemispherical 720mA 12 *Typical values ONLY not guaranteed specifications **Max dissipated power not to exceed 200mW without thermal management Standard circuit configuration shown: custom configurations available upon request.
