Datasheet IR2153 (Infineon) - 5
ManufacturerInfineon
DescriptionSelf-Oscillating Half-Bridge Driver
Pages / Page9 / 5 — IR2153(D)(S) & (PbF). NOTE:For new designs, we recommend. IR’s new …
File Format / SizePDF / 223 Kb
IR2153(D)(S) & (PbF). NOTE:For new designs, we recommend. IR’s new product IRS2153D. Electrical Characteristics (cont.)
IR2153(D)(S) & (PbF) NOTE:For new designs, we recommend IR’s new product IRS2153D Electrical Characteristics (cont.)
IR2153(D)(S) & (PbF) NOTE:For new designs, we recommend IR’s new product IRS2153D Electrical Characteristics (cont.) Gate Driver Output Characteristics Symbol Definition Min. Typ. Max. Units Test Conditions
VOH High level output voltage, VBIAS -VO — 0 100 IO = OA VOL Low-level output voltage, VO — 0 100 IO = OA mV VOL_UV UV-mode output voltage, VO — 0 100 IO = OA VCC ≤ VCCUV- tr Output rise time — 80 150 tf Output fall time — 45 100 nsec tsd Shutdown propogation delay — 660 — td Output deadtime (HO or LO) 0.75 1.20 1.65 μsec
Lead Definitions Symbol Description
VCC Logic and internal gate drive supply voltage RT Oscillator timing resistor input CT Oscillator timing capacitor input COM IC power and signal ground LO Low side gate driver output VS High voltage floating supply return HO High side gate driver output VB High side gate driver floating supply
Lead Assignments
8 Lead PDIP 8 Lead SOIC
IR2153D IR2153(S)
NOTE: The IR2153D is offered in 8 lead PDIP only. www.irf.com 5
