Datasheet AP7179D (Diodes)
Manufacturer | Diodes |
Description | 3A, Ultra Low Noise, High Accuracy, LDO Voltage Regulator |
Pages / Page | 20 / 1 — AP7179D. 3A, ULTRA LOW NOISE, HIGH ACCURACY, LDO VOLTAGE REGULATOR. … |
File Format / Size | PDF / 2.8 Mb |
AP7179D. 3A, ULTRA LOW NOISE, HIGH ACCURACY, LDO VOLTAGE REGULATOR. Description. Pin Assignments. (Top View)
AP7179D 3A, ULTRA LOW NOISE, HIGH ACCURACY, LDO VOLTAGE REGULATOR Description Pin Assignments
The DIODES™ AP7179D is a high output current (3A), low-dropout
(Top View)
regulator capable of sourcing 3A with 180mV maximum dropout, low- noise (4.4μVRMS), high output voltage accuracy (1%). The device T T D output voltage is pin-programmable from 0.8V to 3.95V using a PCB U U N O O G IN IN layout and adjustable from 0.8V to 5.0V using an external resistor 0 9 8 7 6 2 1 1 1 1 divider. The device supports a lower input voltage of 1.1V, which makes it flexible to use and requires a lower component count. OUT 1 15 IN SNS 2 14 EN The device’s low noise (4.4μVRMS), high PSRR, and high output current capability makes it ideal to power noise-sensitive devices FB 3 Thermal Pad 13 NR/SS such as high-performance serializers and deserializers (SerDes), PG 4 12 NC analog-to-digital converters (ADCs), digital-to-analog converters 50mV 5 11 1.6V (DACs), and RF components. 6 7 8 9 0 1 High output accuracy, remote sensing, excellent transient V V D V V performance, and soft-start capabilities also make the AP7179D ideal m m N m m 0 0 0 0 0 0 G 0 0 to power digital loads such as field-programmable gate arrays 1 2 4 8 (FPGAs), digital signal processors (DSPs), and application-specific integrated circuits (ASICs).
W-QFN3535-20 (Type A1)
The enable control and a power-good indicator provide easy and accessible power-sequence control. Output noise immunity is enhanced by adding a bypass capacitor on NR/SS pin. The AP7179D is packaged in the W-QFN3535-20 (Type A1) package.
Features Applications
Low VIN and Wide VIN Range: 1.1V to 6.5V Portable electronic devices Low Dropout Voltage: 180mV at 3A Digital loads: SerDes, FPGAs, and DSPs VOUT Accuracy ±1% Over Line, Load, and Temperature Analog circuits applications: VCO, ADC, DAC, and LVDS Pin-Strapped Output Voltage Test and measurement equipment Output Voltage Range: 0.8V to 3.95V Adjustable Output Voltage Output Voltage Range: 0.8V to 5.5V Ultra-High PSRR: 40dB at 500kHz Output Voltage Noise: 4.4μVRMS at 0.8V Output 7.7μVRMS at 5.0V Output Adjustable Soft-Start Output Open-Drain Power-Good Indicator Function Stable with a 47μF or Larger Ceramic Output Capacitor Excellent Load Transient Response Enable Control
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
For automotive applications requiring specific change control (i.e. parts qualified to AEC-Q100/101/104/200, PPAP capable, and manufactured in IATF 16949 certified facilities), please contact us or your local Diodes representative. https://www.diodes.com/quality/product-definitions/
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. AP7179D 1 of 20 January 2023 Document number: DS42129 Rev. 2 - 2
www.diodes.com
© 2023 Copyright Diodes Incorporated. All Rights Reserved.
