Datasheet SB560L (PanJit)
ManufacturerPanJit
DescriptionLow Vf Schottky Barrier Rectifiers
Pages / Page4 / 1 — SB560L. LOW VF SCHOTTKY BARRIER RECTIFIERS. VOLTAGE 60 Volt CURRENT 5 …
File Format / SizePDF / 248 Kb
SB560L. LOW VF SCHOTTKY BARRIER RECTIFIERS. VOLTAGE 60 Volt CURRENT 5 Ampere FEATURES
Datasheet SB560L PanJit
SB560L
1.0(25.4)MIN. • Plastic package has Underwriters Laboratory
Flammability Classification 94V-O utilizing
Flame Retardant Epoxy Molding Compound. 0.052(1.3)
0.048(1.2) • For use in low voltage, high frequency inverters, free wheeling,
and polarity protection applications.
0.375(9.5)
0.285(7.2) • Lead free in compliance with EU RoHS 2011/65/EU directive
• Green molding compound as per IEC61249 Std (Halogen Free) 0.210(5.3)
0.188(4.8) 1.0(25.4)MIN. MECHANICAL DATA
• Case: DO-201AD Molded plastic
• Terminals: Axial leads, solderable per MIL-STD-750,Method 2026
• Polarity: Color band denotes cathode
• Weight: 0.04 ounces, 1.142 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. PA RA M E T E R SY MBO L VA L UE UNI TS M a ximum R e c ur r e nt P e a k R e ve r s e Vo lt a g e V RRM 60 V M a ximum R M S Vo lt a g e V RM S 42 V M a ximum D C B lo c k ing Vo lt a g e V DC 60 V M a ximum A ve r a g e F o r w a r d R e c t if i e d C ur r e nt ( S e e F ig 3 ) I F ( AV) 5 A P e a k F o r w a r d S ur g e C ur r e nt : 8 . 3 m ing le ha lf s ine -w a ve
s up e r imp o s e d o n r a t e d lo a d I FSM 150 A M a ximum F o r w a r d Vo l t a g e a t 5 A VF 0. 49 V IR 0.5
50 mA R θJ L 10 TJ -55 t o + 150 O C T ST G -55 t o + 150 O C M a ximum D C R e ve r s e Cur r e nt a t R a t e d D C B lo c k i ng
Vo lt a g e
Ty p ic a l The r ma l R e s i s t a nc e ( No t e 1 )
O p e r a t ing J unc t io n Te mp e r a t ur e R a ng e
S t o r a g e Te mp e r a t ur e R a ng e TJ= 2 5 OC
TJ= 1 00 OC O C / W NOTES :
1. Thermal Resistance Junction to Lead Vertical PC Board Mounting 0.375” (9.5mm) Lead Lengths. May 18,2016­REV.03 PAGE . 1
