Datasheet SPSB081 (STMicroelectronics) - 6
DescriptionAutomotive Power Management IC with LIN and CAN-FD
Pages / Page137 / 6 — SPSB081. Pin description. Table 1. Pin function. Pin SPSB081x Pin …
SPSB081. Pin description. Table 1. Pin function. Pin SPSB081x Pin SPSB081Cx Pin name. Description. I/O type. DS14048. Rev 3. page 6/137
SPSB081 Pin description Table 1 Pin function Pin SPSB081x Pin SPSB081Cx Pin name Description I/O type DS14048 Rev 3 page 6/137
SPSB081 Pin description Table 1. Pin function Pin SPSB081x Pin SPSB081Cx Pin name Description I/O type
Wake-up inputs 1: input pin for static or cyclic monitoring of external 1 1 WU1 I contacts DIR → direct HS drive 2 2 DIR/WU2 I WU2 → input pin for static or cyclic monitoring of external contacts Voltage regulator 2 or tracker 2 output: 5 V or 3.3 V supply for 3 3 V2 external loads or CAN FD transceiver O V2 pin is protected against reverse supply 4 4 OUT4 High-side-driver output to drive LEDs, sensors or to supply contacts O 5 5 OUT3 High-side-driver output to drive LEDs, sensors or to supply contacts O 6 6 OUT2 High-side-driver output to drive LEDs, sensors or to supply contacts O 7 7 OUT1 High-side-driver output to drive LEDs, sensors or to supply contacts O Power supply voltage for power stage outputs OUT1, OUT2, OUT3, and OUT4 (external reverse battery protection required). 8 8 VS P For this input, a ceramic capacitor as close as possible to GND is recommended 9 9 NC Not connected - 10 10 Debug Debug input to deactivate the window watchdog (high active) I 11 11 SGND Signal ground P 12 12 TxD_C CAN transmit data input I 13 - TxD_L LIN transmit data input I Current monitor output: depending on the selected multiplexer bits 14 14 CM of the control register this output sources an image of the instant O current through the corresponding high side driver with a fixed ratio Logical error indication output. 15 15 DIAGN O Active low 16 16 NINT indicates device errors, warning, and local/remote wake-up events O 17 17 RxD_C CAN receive data output (push pull output stages) O RxDL → LIN receive data output (only for SPSB0815 and 18 - RxD_L O SPSB0813) 19 19 CLK SPI: serial clock input I 20 20 DO SPI: serial data output (push pull output stage) O 21 21 DI SPI: serial data input I 22 22 CSN SPI: chip select not input I NReset output to microcontroller; internal pull-up of typical 25 kΩ 23 23 NRESET O (active low output stage) Voltage regulator 1 output: 5 V or 3.3 V supply, for example, 24 24 V1 O microcontroller, CAN FD transceiver 25 25 NC Not connected - Power supply voltage to feed the internal voltage regulators; all internal regulated voltages for analog and digital functionality; LIN transceiver; CAN transceiver and the wake-up features (external 26 26 VSREG P reverse battery protection required/diode). For this input, a ceramic capacitor as close as possible to GND and an electrolytic backup capacitor are recommended 27 27 NC Not connected -
DS14048
Rev 3 page 6/137
Document Outline Device summary Features Applications Description 1 Block diagram and pin description 1.1 Block diagram 1.2 Pin description 2 Maximum ratings 2.1 Operating range 2.1.1 Supply voltage ranges 2.2 Absolute maximum ratings 2.3 Temperature ranges and thermal data 3 Functional description 3.1 Supply VS and VSREG 3.2 Voltage regulators 3.2.1 Voltage regulator: V1 3.2.2 Voltage regulator: V2 3.2.3 Voltage regulator failure 3.2.4 Short to ground detection 3.2.5 Voltage regulator behavior 3.3 Operating modes 3.3.1 Active mode 3.3.2 SW-debug mode 3.3.3 V1_standby mode 3.3.4 Interrupt 3.3.5 VBAT_standby mode 3.4 Wake-up from standby modes 3.4.1 Wake-up inputs 3.5 Functional overview (truth table) 3.6 Configurable window watchdog 3.6.1 Change watchdog timing 3.7 Fail safe mode 3.7.1 Temporary failures 3.7.2 Non recoverable failures - Forced in VBAT_standby mode 3.8 Reset output (NRESET) 3.9 DIAGN output 3.10 V1 overvoltage detection 3.11 LIN bus interfaces (only for SPSB0815 and SPSB0813) 3.11.1 Features 3.11.2 Error handling 3.11.2.1 Dominant TXD_L time out 3.11.2.2 Permanent recessive 3.11.2.3 Permanent dominant 3.11.3 Wake-up from standby modes 3.11.3.1 Pattern wake-up (default) 3.11.3.2 Status change wake-up - Recessive-to-dominant 3.11.3.3 Status change wake-up - Dominant-to-recessive 3.12 CAN FD bus transceiver 3.12.1 Features 3.12.2 CAN transceiver supply 3.12.3 CAN transceiver operating modes 3.12.4 CAN error handling 3.12.4.1 Dominant TXDC time out 3.12.4.2 CAN bus permanent recessive 3.12.4.3 CAN Permanent dominant 3.12.4.4 RXDC permanent recessive 3.12.5 Wake-up by CAN 3.12.6 CAN receive only mode 3.12.7 CAN looping mode 3.13 Power supply fail 3.13.1 VS supply failure 3.13.2 VSREG supply failure 3.14 Thermal state machine 3.15 Power outputs OUT1..4 3.16 Open-load detection 3.17 Overcurrent detection 3.18 Current monitor 3.19 Constant current mode 3.20 Temperature warning and shutdown 3.21 Thermal clusters 3.22 Functional safety management 4 Serial peripheral interface (SPI) 4.1 ST-SPI 4.1.1 Physical layer 4.2 Signal description 4.2.1 Clock and data characteristics 4.2.2 Communication protocol 4.2.2.1 SDI frame 4.2.2.2 Operating code 4.2.2.3 Advanced operation codes 4.2.2.4 Data-in payload 4.2.2.5 SDO frame 4.2.2.6 Global status byte (GSB) 4.2.2.7 Data-out payload 4.3 Address definition 4.3.1 Information registers 4.3.1.1 Device identification registers 4.3.1.2 SPI modes 4.3.1.3 SPI burst read 4.3.1.4 SPI data length 4.3.2 Device application registers (RAM) 4.4 Protocol failure detection 4.4.1 Clock monitor 4.4.2 SCK polarity (CPOL) check 4.4.3 SCK phase (CPHA) check 4.4.4 CSN timeout 4.4.5 SDI stuck at GND 4.4.6 SDI stuck at HIGH 4.4.7 SDO stuck at GND and HIGH 5 Electrical characteristics 5.1 Oscillator 5.2 Power-on reset (VSREG) 5.3 Voltage regulator V1 5.4 Voltage regulator V2 5.5 Reset output 5.6 DIAGN output 5.7 Watchdog 5.8 Current monitor output (CM) 5.9 Outputs OUT1..OUT4 5.10 Power outputs switching times 5.11 Output current threshold 5.12 Wake-up inputs (WU1, DIR/WU2) 5.13 CAN FD transceiver 5.14 LIN transceiver (only for SPSB0815 and SPSB0813) 5.15 SPI 5.16 Debug input 5.17 Interrupt output 5.18 Timer1 and Timer2 5.19 SGND loss comparator 6 Application 7 SPI registers 7.1 Global status byte (GSB) 7.2 Control registers overview 7.3 Status register overview 7.4 Control registers 7.5 Status registers 8 Package information 8.1 QFN32L Epad (5.0x5.0x1.0 mm) package information Revision history
