Datasheet SPSB081 (STMicroelectronics) - 9
DescriptionAutomotive Power Management IC with LIN and CAN-FD
Pages / Page137 / 9 — SPSB081. Absolute maximum ratings. Symbol. Parameter. Condition. Min Typ. …
SPSB081. Absolute maximum ratings. Symbol. Parameter. Condition. Min Typ. Max. Unit. Table 3. ESD protection. Item. Values. DS14048. Rev 3
SPSB081 Absolute maximum ratings Symbol Parameter Condition Min Typ Max Unit Table 3 ESD protection Item Values DS14048 Rev 3
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 10 link to page 10
VDIAGN Logic output - -0.3 - V1 + 0.3 V VTXDC Logic input - -0.3 - V1 + 0.3 V VTXDL Logic input - -0.3 - V1 + 0.3 V VDEBUG Debug input pin voltage range - -0.3 - V1 + 0.3 V VWU1 DC wake-up input voltage - -0.3 - VSREG + 0.3 V VDIR/WU2 DC wake-up input voltage - -0.3 - VSREG + 0.3 V VLIN LIN bus I/O voltage range - -27 - 40 V IINPUT Current injection into Vs related input pins - - 20 - mA IOUT_INJ Current injection into vs related outputs - - 20 - mA VCANSUP CAN supply - -0.3 - 5.25 V VCANH CAN bus I/O voltage range - -27 - 40 V VCANL CAN bus I/O voltage range - -27 - 40 V VCANH - VCANL Differential CAN-Bus voltage - -5 - 10 V VOUT1 Output voltage - -0.3 - VS + 0.3 V VOUT2 Output voltage - -0.3 - VS + 0.3 V VOUT3 Output voltage - -0.3 - VS + 0.3 V VOUT4 Output voltage - -0.3 - VS + 0.3 V I Maximum cumulated current at VS drawn by VS - -1.25 - 1.25 A OUT1; OUT2; OUT3; OUT4 I Maximum cumulated current at VSREG drawn VSREG - -1.25 - 1.25 A by LDO1; LDO2; LIN; CAN at wake-up IOUT1 Output current(2) - -1.25 - 1.25 A IOUT2 Output current(2) - -1.25 - 1.25 A IOUT3 Output current(2) - -1.25 - 1.25 A IOUT4 Output current(2) - -1.25 - 1.25 A ISGND Maximum current at SGND(2) - -1.25 - 1.25 A IPGND Maximum current at PGND(2) - -1.25 - 1.25 A GND pins PGND versus SGND - -0.3 - 0.3 V 1. SPSB081 is protected against V2 shorted to VSREG and V2 reverse biasing when VSREG is higher than 3.5 V. 2. Values for the absolute maximum DC current through the bond wires. This value does not consider maximum power dissipation or other limits. All maximum ratings are absolute ratings. Leaving the limitation of any of these values may cause an irreversible damage of the integrated circuit! Loss of ground or ground shift with externally grounded loads: ESD structures are configured for nominal currents only. If external loads are connected to different grounds, the current load must be limited to this nominal current.
Table 3. ESD protection Item Parameter Condition Values Unit
Pins All pins HBM (1) ±2 kV Power output pin OUT1 HBM(2) ±4 kV
DS14048
Rev 3 page 9/137
Document Outline Device summary Features Applications Description 1 Block diagram and pin description 1.1 Block diagram 1.2 Pin description 2 Maximum ratings 2.1 Operating range 2.1.1 Supply voltage ranges 2.2 Absolute maximum ratings 2.3 Temperature ranges and thermal data 3 Functional description 3.1 Supply VS and VSREG 3.2 Voltage regulators 3.2.1 Voltage regulator: V1 3.2.2 Voltage regulator: V2 3.2.3 Voltage regulator failure 3.2.4 Short to ground detection 3.2.5 Voltage regulator behavior 3.3 Operating modes 3.3.1 Active mode 3.3.2 SW-debug mode 3.3.3 V1_standby mode 3.3.4 Interrupt 3.3.5 VBAT_standby mode 3.4 Wake-up from standby modes 3.4.1 Wake-up inputs 3.5 Functional overview (truth table) 3.6 Configurable window watchdog 3.6.1 Change watchdog timing 3.7 Fail safe mode 3.7.1 Temporary failures 3.7.2 Non recoverable failures - Forced in VBAT_standby mode 3.8 Reset output (NRESET) 3.9 DIAGN output 3.10 V1 overvoltage detection 3.11 LIN bus interfaces (only for SPSB0815 and SPSB0813) 3.11.1 Features 3.11.2 Error handling 3.11.2.1 Dominant TXD_L time out 3.11.2.2 Permanent recessive 3.11.2.3 Permanent dominant 3.11.3 Wake-up from standby modes 3.11.3.1 Pattern wake-up (default) 3.11.3.2 Status change wake-up - Recessive-to-dominant 3.11.3.3 Status change wake-up - Dominant-to-recessive 3.12 CAN FD bus transceiver 3.12.1 Features 3.12.2 CAN transceiver supply 3.12.3 CAN transceiver operating modes 3.12.4 CAN error handling 3.12.4.1 Dominant TXDC time out 3.12.4.2 CAN bus permanent recessive 3.12.4.3 CAN Permanent dominant 3.12.4.4 RXDC permanent recessive 3.12.5 Wake-up by CAN 3.12.6 CAN receive only mode 3.12.7 CAN looping mode 3.13 Power supply fail 3.13.1 VS supply failure 3.13.2 VSREG supply failure 3.14 Thermal state machine 3.15 Power outputs OUT1..4 3.16 Open-load detection 3.17 Overcurrent detection 3.18 Current monitor 3.19 Constant current mode 3.20 Temperature warning and shutdown 3.21 Thermal clusters 3.22 Functional safety management 4 Serial peripheral interface (SPI) 4.1 ST-SPI 4.1.1 Physical layer 4.2 Signal description 4.2.1 Clock and data characteristics 4.2.2 Communication protocol 4.2.2.1 SDI frame 4.2.2.2 Operating code 4.2.2.3 Advanced operation codes 4.2.2.4 Data-in payload 4.2.2.5 SDO frame 4.2.2.6 Global status byte (GSB) 4.2.2.7 Data-out payload 4.3 Address definition 4.3.1 Information registers 4.3.1.1 Device identification registers 4.3.1.2 SPI modes 4.3.1.3 SPI burst read 4.3.1.4 SPI data length 4.3.2 Device application registers (RAM) 4.4 Protocol failure detection 4.4.1 Clock monitor 4.4.2 SCK polarity (CPOL) check 4.4.3 SCK phase (CPHA) check 4.4.4 CSN timeout 4.4.5 SDI stuck at GND 4.4.6 SDI stuck at HIGH 4.4.7 SDO stuck at GND and HIGH 5 Electrical characteristics 5.1 Oscillator 5.2 Power-on reset (VSREG) 5.3 Voltage regulator V1 5.4 Voltage regulator V2 5.5 Reset output 5.6 DIAGN output 5.7 Watchdog 5.8 Current monitor output (CM) 5.9 Outputs OUT1..OUT4 5.10 Power outputs switching times 5.11 Output current threshold 5.12 Wake-up inputs (WU1, DIR/WU2) 5.13 CAN FD transceiver 5.14 LIN transceiver (only for SPSB0815 and SPSB0813) 5.15 SPI 5.16 Debug input 5.17 Interrupt output 5.18 Timer1 and Timer2 5.19 SGND loss comparator 6 Application 7 SPI registers 7.1 Global status byte (GSB) 7.2 Control registers overview 7.3 Status register overview 7.4 Control registers 7.5 Status registers 8 Package information 8.1 QFN32L Epad (5.0x5.0x1.0 mm) package information Revision history
