Datasheet LM158, LM258, LM358, LM258A, LM358A (STMicroelectronics) - 8
DescriptionLow-Power Dual Operational Amplifiers
Pages / Page25 / 8 — Electrical characteristics. LM158, LM258, LM358, LM158A, LM258A,. LM358A. …
Electrical characteristics. LM158, LM258, LM358, LM158A, LM258A,. LM358A. Symbol. Parameter. Min. Typ. Max. Unit. Notes:
Electrical characteristics LM158, LM258, LM358, LM158A, LM258A, LM358A Symbol Parameter Min Typ Max Unit Notes:
link to page 8
Electrical characteristics LM158, LM258, LM358, LM158A, LM258A, LM358A Symbol Parameter Min. Typ. Max. Unit
VCC+ = 30 V, RL = 2 kΩ connected to VCC-, 26 27 Tamb = 25 °C VCC+ = 30 V, RL = 2 kΩ connected to VCC-, 26 Tmin ≤ Tamb ≤ Tmax VCC+ = 30 V, RL = 10 kΩ connected to VCC-, 27 28 Tamb = 25 °C VOH High level output voltage V VCC+ = 30 V, RL = 10 kΩ connected to VCC-, 27 Tmin ≤ Tamb ≤ Tmax VCC+ = 5 V, RL = 2 kΩ connected to VCC-, 3.5 Tamb = 25 °C VCC+ = 5 V, RL = 2 kΩ connected to VCC-, 3 Tmin ≤ Tamb ≤ Tmax RL = 10 kΩ connected to VCC- 5 20 VOL Low level output voltage mV Tmin ≤ Tamb ≤ Tmax 20 V + CC = 15 V, Vi = 0.5 to 3 V, RL = 2 kΩ, SR Slew rate C V/µs L = 100 pF, unity gain 0.3 0.6 V + CC = 30 V, f = 100 kHz, Vin = 10 mV, GBP Gain bandwidth product 0.7 1.1 MHz RL = 2 kΩ, CL = 100 pF f = 1 kHz, Av = 20 dB, RL = 2 kΩ, Vo = 2 Vpp, THD Total harmonic distortion 0.02 % CL = 100 pF, VO = 2 Vpp Equivalent input noise e + n f = 1 kHz, Rs = 100 Ω, VCC = 30 V 55 voltage Vo1/Vo2 Channel separation (3) 1 kHz ≤ f ≤ 20 kHz 120 dB
Notes:
(1)V + + o = 1.4 V, Rs = 0 Ω, 5 V < VCC < 30 V, 0 < Vic < VCC - 1.5 V (2)The direction of the input current is out of the IC. This current is essentially constant, independent of the state of the output so there is no change in the load on the input lines. (3)Due to the proximity of external components, ensure that stray capacitance between these external parts does not cause coupling. Typically, this can be detected because this type of capacitance increases at higher frequencies. 8/25 DocID2163 Rev 15 Document Outline 1 Schematic diagram 2 Package pin connections 3 Absolute maximum ratings 4 Electrical characteristics 5 Electrical characteristic curves 6 Typical applications 7 Package information 7.1 SO8 package information 7.2 MiniSO8 package information 7.3 DFN8 2x2 package information 7.4 TSSOP8 package information 8 Ordering information 9 Revision history
