Datasheet NCP565, NCV565 (ON Semiconductor) - 4
ManufacturerON Semiconductor
DescriptionLinear Regulator -Low Dropout 1.5 A
Pages / Page17 / 4 — NCP565, NCV565. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. …
File Format / SizePDF / 428 Kb
NCP565, NCV565. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. Max. Unit. ADJUSTABLE OUTPUT VERSION. FIXED OUTPUT VOLTAGE
NCP565, NCV565 ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Typ Max Unit ADJUSTABLE OUTPUT VERSION FIXED OUTPUT VOLTAGE
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
(Vin = Vout + 1.6 V, Vout = 0.9 V, TA= 25°C, Cin = Cout = 150 mF, unless otherwise noted, Note 4.)
Reference Voltage (10 mA < Iout < 1.5 A; Vout + 1.6 V < Vin < 9.0 V; TA = −10 to 105°C) Vref 0.882 0.9 0.918 V (−2%) (+2%) Reference Voltage (10 mA < Iout < 1.5 A; Vout + 1.6 V < Vin < 9.0 V; TA = −40 to 125°C) Vref 0.873 0.9 0.927 V (−3%) (+3%) ADJ Pin Current (Note 5) IAdj − 30 − nA Line Regulation (Iout = 10 mA) (Note 5) Regline − 0.03 − % Load Regulation (10 mA < Iout < 1.5 A) (Note 5) Regload − 0.03 − % Dropout Voltage (Iout = 1.5 A, Vout = 2.5 V) (Note 6) Vdo − 0.9 1.3 V Current Limit Ilim 1.6 3.3 − A Ripple Rejection (120 Hz; Iout = 1.5 A) (Note 5) RR − 85 − dB Ripple Rejection (1 kHz; Iout = 1.5 A) (Note 5) RR − 75 − dB Ground Current (Iout = 1.5 A) IGND − 1.5 3.0 mA Output Noise Voltage (f = 100 Hz to 100 kHz, Iout = 1.5 A) (Note 5) Vn − 28 − mVrms Thermal Shutdown Protection (Note 5) TSHD − 160 − _C
(Vin = Vout + 1.6 V, TA = 25°C, Cin = Cout = 150 mF, unless otherwise noted, Note 4.) Output Voltage (10 mA < Iout < 1.5 A; 2.8 V < Vin < 9.0 V; TA = −10 to 105°C) Vout 1.176 1.2 1.224 V 1.2 V version (−2%) (+2%) Output Voltage (10 mA < Iout < 1.5 A; 2.8 V < Vin < 9.0 V; TA = −40 to 125°C) Vout 1.164 1.2 1.236 V 1.2 V version (−3%) (+3%) Output Voltage (10 mA < Iout < 1.5 A; 3.1 V < Vin < 9.0 V; TA = −10 to 105°C) Vout 1.470 1.5 1.530 V 1.5 V version (−2%) (+2%) Output Voltage (10 mA < Iout < 1.5 A; 3.1 V < Vin < 9.0 V; TA = −40 to 125°C) Vout 1.455 1.5 1.545 V 1.5 V version (−3%) (+3%) Output Voltage (10 mA < Iout < 1.5 A; 4.4 V < Vin < 9.0 V; TA = −10 to 105°C) Vout 2.744 2.8 2.856 V 2.8 V version (−2%) (+2%) Output Voltage (10 mA < Iout < 1.5 A; 4.4 V < Vin < 9.0 V; TA = −40 to 125°C) Vout 2.716 2.8 2.884 V 2.8 V version (−3%) (+3%) Output Voltage (10 mA < Iout < 1.5 A; 4.6 V < Vin < 9.0 V; TA = −10 to 105°C) Vout 2.940 3.0 3.060 V 3.0 V version (−2%) (+2%) Output Voltage (10 mA < Iout < 1.5 A; 4.6 V < Vin < 9.0 V; TA = −40 to 125°C) Vout 2.910 3.0 3.090 V 3.0 V version (−3%) (+3%) Output Voltage (10 mA < Iout < 1.5 A; 4.9 V < Vin < 9.0 V; TA = −10 to 105°C) Vout 3.234 3.3 3.366 V 3.3 V version (−2%) (+2%) Output Voltage (10 mA < Iout < 1.5 A; 4.9 V < Vin < 9.0 V; TA = −40 to 125°C) Vout 3.201 3.3 3.399 V 3.3 V version (−3%) (+3%) Line Regulation (Iout = 10 mA) (Note 5) Regline − 0.03 − % Load Regulation (10 mA < Iout < 1.5 A) (Note 5) Regload − 0.03 − % Dropout Voltage (Iout = 1.5 A, Vout = 2.5 V) (Note 6) Vdo − 0.9 1.3 V Current Limit Ilim 1.6 3.3 − A Ripple Rejection (120 Hz; Iout = 1.5 A) (Note 5) RR − 85 − dB Ripple Rejection (1 kHz; Iout = 1.5 A) (Note 5) RR − 75 − dB Ground Current (Iout = 1.5 A) IGND − 1.5 3.0 mA Output Noise Voltage (f = 100 Hz to 100 kHz, Vout = 1.2 V, Iout = 1.5 A) (Note 5) Vn − 38 − mVrms Thermal Shutdown Protection (Note 5) TSHD − 160 − _C 4. Performance guaranteed over specified operating conditions by design, guard banded test limits, and/or characterization, production tested at TJ = TA = 25_C. Low duty cycle pulse techniques are used during testing to maintain the junction temperature as close to ambient as possible. 5. Typical values are based on design and/or characterization. 6. Dropout voltage is a measurement of the minimum input/output differential at full load.
www.onsemi.com 4
