Datasheet L272 (STMicroelectronics) - 3
DescriptionDual Power Operational Amplifiers
Pages / Page10 / 3 — L272. ABSOLUTE MAXIMUM RATINGS. Symbol. Parameter. Value. Unit. THERMAL …
File Format / SizePDF / 913 Kb
L272. ABSOLUTE MAXIMUM RATINGS. Symbol. Parameter. Value. Unit. THERMAL DATA. Powerdip. SO16. Minidip. ELECTRICAL CHARACTERISTICS
L272 ABSOLUTE MAXIMUM RATINGS Symbol Parameter Value Unit THERMAL DATA Powerdip SO16 Minidip ELECTRICAL CHARACTERISTICS
Vs Supply Voltage 28 V Vi Input Voltage Vs Vi Differential Input Voltage ± Vs Io DC Output Current 1 A Ip Peak Output Current (non repetitive) 1.5 A Ptot Power Dissipation at: Tamb = 80°C (L272), Tamb = 50°C (L272M), Tcase = 90 °C (L272D) 1.2 W T 5 W case = 75 °C (L272) Top Operating Temperature Range (L272D) – 40 to 85 °C Tstg, Tj Storage and Junction Temperature – 40 to 150 °C
THERMAL DATA Symbol Parameter Powerdip SO16 Minidip Unit
Rth j-case Thermal Resistance Junction-pins Max. 15 – * 70 oC/W Rth j-amb Thermal Resistance Junction-ambient Max. 70 – 100 oC/W Rth j-alumina Thermal Resistance Junction-alumina Max. – ** 50 – oC/W * Thermal resistance junction-pin 4 ** Thermal resistance junctions-pins with the chip soldered on the middle of an alumina supporting substrate measuring 15x 20mm; 0.65mm thickness and infinite heatsink.
(VS = 24V, Tamb = 25oC unless otherwise specified)
Symbol Parameter Test Conditions Min. Typ. Max. Unit
Vs Supply Voltage 4 28 V VS Is Quiescent Drain Current VO = Vs = 24V 8 12 mA 2 Vs = 12V 7.5 11 mA Ib Input Bias Current 0.3 2.5 µA Vos Input Offset Voltage 15 60 mV Ios Input Offset Current 50 250 nA SR Slew Rate 1 V/µs B Gain-bandwidth Product 350 kHz Ri Input Resistance 500 kΩ Gv O. L. Voltage Gain f = 100Hz 60 70 dB f = 1kHz 50 dB eN Input Noise Voltage B = 20kHz 10 µV IN Input Noise Current B = 20kHz 200 pA CRR Common Mode Rejection f = 1kHz 60 75 dB SVR Supply Voltage Rejection f = 100Hz, RG = 10kΩ, VR = 0.5V dB Vs = 24V 70 Vs = ± 12V 54 62 Vs = ± 6V 56 Vo Output Voltage Swing Ip = 0.1A 23 V Ip = 0.5A 21 22.5 V Cs Channel Separation f = 1 kHz; RL =10Ω, Gv = 30dB dB Vs = 24V 60 Vs = ± 6V 60 d Distortion f = 1kHz, Gv = 3 dB, Vs = 24V, RL = ∞ 0.5 % Tsd Thermal Shutdown Junction 145 °C Temperature 3/10
