Datasheet X100-7 THD (First Sensor) - 2
ManufacturerFirst Sensor
DescriptionFirst Sensor PIN PD
Pages / Page2 / 2 — First. Sensor. PIN. PD. Data. Sheet. First. Sensor. PIN. PD. Data. Sheet. …
File Format / SizePDF / 549 Kb
First. Sensor. PIN. PD. Data. Sheet. First. Sensor. PIN. PD. Data. Sheet. Part. Description. X100-7. THD. Part. Description. X100-7. THD. Order. #. 5000040. Order. #
First Sensor PIN PD Data Sheet First Sensor PIN PD Data Sheet Part Description X100-7 THD Part Description X100-7 THD Order # 5000040 Order #
First Sensor PIN PD Data Sheet First Sensor PIN PD Data Sheet Part Description X100-7 THD Part Description X100-7 THD Order # 5000040 Order # 5000040 Dark current (23 °C) Capacitance as fct of reverse bias (23 °C) 1,0E-07 500 450 400 ) A ( 350 ) t 1,0E-08 F n p e 300 r ( r ce cu 250 n k cita 200 Dar a 1,0E-09 150 Cap 100 50 1,0E-10 0 0 10 20 30 0 10 20 30 40 50 Reverse bias (V) Reverse bias (V) Package dimension: Small quantities: Foam pad, boxed (12 cm x 16.5 cm) Handling: Please refer to document "Instructions for handling and processing" Disclaimer: Due to our strive for continuous improvement, specifications are subject to change within our PCN policy according to JESD46C. Rev. 24/01/2018 subject to change without notice www.first-sensor.com contact@first-sensor.com Page 2/2
