Datasheet LMP2015, LMP2016 (National Semiconductor) - 4
ManufacturerNational Semiconductor
DescriptionSingle/Dual High Precision, Rail-to-Rail Output Operational Amplifier
Pages / Page16 / 4 — Symbol. Parameter. Conditions. Min. Typ. Max. Units. 4.95. 0.085. 4.875. …
File Format / SizePDF / 527 Kb
Symbol. Parameter. Conditions. Min. Typ. Max. Units. 4.95. 0.085. 4.875. 0.140. 4.91. LMP2015 Single/LMP2016 Dual. 0.095. 4.855. 0.150. 100. 1.50
Symbol Parameter Conditions Min Typ Max Units 4.95 0.085 4.875 0.140 4.91 LMP2015 Single/LMP2016 Dual 0.095 4.855 0.150 100 1.50
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
(Note 5) (Note 4) (Note 5) V Output Swing 4.96 4.978 O R = 10 kΩ to 2.5V L (LMP2015 only) V (diff) = ±0.5V
4.95
IN V 0.040 0.070
0.085
R = 2 kΩ to 2.5V 4.895 4.919 L V (diff) = ±0.5V
4.875
IN V 0.091 0.115
0.140
Output Swing R = 10 kΩ to 2.5V 4.92 4.978 L (LMP2016 only) V (diff) = ±0.5V
IN V 0.040 0.080
0.095
R = 2 kΩ to 2.5V 4.875 4.919 L V (diff) = ±0.5V
4.855
IN V 0.0.91 0.125
0.150
A Open Loop Voltage Gain 130 VOL R = 10 kΩ 105 L
100
dB R = 2 kΩ 95 132 L
90
I Output Current Sourcing, V = 0V 8 15 O O V (diff) = ±0.5V
6
IN mA Sinking, V = 5V 8 17 O V (diff) = ±0.5V
6
IN I Supply Current per Channel 0.930 1.20 S mA
1.50 5V AC Electrical Characteristics
T = 25°C, V+ = 5V, V− = 0V, V = 2.5V, V = 2.5V, and R > 1 MΩ. A CM O L
Boldface
limits apply at the temperature extremes.
(Note 5) (Note 4) (Note 5) GBW Gain-Bandwidth Product 3 MHz SR Slew Rate 4 V/μs θ Phase Margin 60 deg m G Gain Margin −15 dB m e Input-Referred Voltage Noise 35 n nV/ i Input-Referred Current Noise n pA/ e p-p Input-Referred Voltage Noise n R = 100Ω, DC to 10 Hz 850 nV S PP t Input Overload Recovery Time 50 ms rec
Note 1:
Absolute Maximum Ratings indicate limits beyond which damage may occur. Operating Ratings indicate conditions for which the device is intended to be functional, but specific performance is not guaranteed. For guaranteed specifications and test conditions, see the Electrical Characteristics.
Note 2:
Human Body Model, applicable std. MIL-STD-883, Method 3015.7. Machine Model, applicable std. JESD22-A115-A (ESD MM std. of JEDEC) Field-Induced Charge-Device Model, applicable std. JESD22-C101-C (ESD FICDM std. of JEDEC).
Note 3:
The maximum power dissipation is a function of T , θ . The maximum allowable power dissipation at any ambient temperature is P = (T – J(MAX) JA D J(MAX) T )/ θ . All numbers apply for packages soldered directly onto a PC Board. A JA
Note 4:
Typical values represent the most likely parametric norm as determined at the time of characterization. Actual typical values may vary over time and will also depend on the application and configuration. The typical values are not tested and are not guaranteed on shipped production material.
Note 5:
Limits are 100% production tested at 25°C. Limits over the operating temperature range are guaranteed through correlations using statistical quality control (SQC) method. www.national.com 4 Document Outline LMP2015 Single/LMP2016 Dual General Description Features Applications Connection Diagrams Ordering Information Absolute Maximum Ratings Operating Ratings 2.7V DC Electrical Characteristics 2.7V AC Electrical Characteristics 5V DC Electrical Characteristics 5V AC Electrical Characteristics Typical Performance Characteristics Application Information THE BENEFITS OF THE LMP2015/LMP2016'sNO 1/f NOISE OVERLOAD RECOVERY FIGURE 1. Overload Recovery Test NO EXTERNAL CAPACITORS REQUIRED MORE BENEFITS HOW THE LMP2015/LMP2016 WORK FIGURE 2. The Output of a Chopper Stabilized Op Amp (MAX432) FIGURE 3. The Output of the LMP2015/LMP2016 INPUT CURRENTS PRECISION STRAIN GAUGE AMPLIFIER FIGURE 4. Precision Strain Gauge Amplifier FIGURE 5. Composite Amplifier Configuration TABLE 1. Composite Amplifier Measured Performance FIGURE 6. Composite Amplifier Configuration FIGURE 7. AC Coupled ADC Driver LMP2015 AS AN ADC DRIVER FIGURE 8. DC Coupled ADC Driver Physical Dimensions
