Datasheet A6C, A6CV (Omron) - 2
Manufacturer | Omron |
Description | Internally Sealed DIL-IC Type Rotary DIP Switch |
Pages / Page | 3 / 2 — A6C/A6CV. Output Codes 10-position Models. 16-position Models. Code. BCD … |
File Format / Size | PDF / 359 Kb |
A6C/A6CV. Output Codes 10-position Models. 16-position Models. Code. BCD Decimal code. BCD Hexadecimal code. Position. Note:
A6C/A6CV A6C/A6CV
Output Codes 10-position Models 16-position Models Code BCD Decimal code Code BCD Hexadecimal code Position 1 2 4 8 Position 1 2 4 8 0 0 1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
A
B
C
D
E
F
Note:
“●” indicates that the internal switch is ON. ■
Dimensions
(Unit: mm) ●
Top Actuated, 10 Positions
Top Actuated, 16 Positions A6C-10R (N) A6C-16R (N)
0 9 0 1 E 2 8 2 C 4 6.6 6.6±0.2 ±0.2 7 3 6 4 A 6 5 8 5.08 5.08±0.1 ±0.1 9 9±0.2 ±0.2 7.62 ±0.4 7.62 ±0.4 0 0 4.5 3.9 4.5 3.9 8 8±0.3 ±0.3 0.25±0.1 0.5 0.5±0.1 ±0.1 0.25±0.1 2.54 2.54 1.4 8.5 1.4 8.5 ●
Side Actuated, 10 Positions
Side Actuated, 16 Positions A6CV-10R A6CV-16R
9±0.2 (7.1) 9±0.2 (7.1) 9 0 1 0 E 2 8 2 (7.1) C 4 (7.1) 9.1 7 3 9.1 3.3 3.3 12.6 6 4 5 A 6 12.6 8 0.95 0.95 0.5±0.1 0.25±0.1 0.5±0.1 0.25±0.1 2.54 1.4 7.62 2.54 1.4 7.62 8.5 8.5 5.08±0.1 5.08±0.1
Note:
Unless otherwise specified, a tolerance of ±0.4 mm applies to all dimensions. ■
Internal Connections/Terminal arrangement/PCB Dimensions
(Unit: mm)
Contact Form (Top View) Terminal arrangement Mounting holes (top view)
C 8 4 (Single-sided PCB, t = 1.2 to 1.6) A6C A6CV C 8 4 C 8 4 2.54±0.1 Six, 0.8 dia. (min.) holes (See note) 2.54±0.1 9 0 1 8 2 7 3 C 1 2 7.62±0.1 6 4 5 C 1 2 C 1 2 A6C/A6CV Case 5.08±0.1 Actuator side (A6CV)
Note.
0.9 dia. for automatic insertion ■
Precautions
Be sure to read the Safety precautions common to all DIP Switches for correct use. 2
