Datasheet MB2S, MB4S, MB6S (Vishay) - 2
ManufacturerVishay
DescriptionMiniature Glass Passivated Fast Recovery Surface-Mount Bridge Rectifier
Pages / Page5 / 2 — MB2S, MB4S, MB6S. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITIONS. …
File Format / SizePDF / 103 Kb
MB2S, MB4S, MB6S. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITIONS. SYMBOL MB2S. MB4S. MB6S. UNIT. THERMAL CHARACTERISTICS. Notes
MB2S, MB4S, MB6S ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITIONS SYMBOL MB2S MB4S MB6S UNIT THERMAL CHARACTERISTICS Notes
MB2S, MB4S, MB6S
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
Maximum instantaneous forward I voltage per diode F = 0.4 A VF 1.0 V Maximum DC reverse current at rated DC blocking TA = 25 °C 5.0 I μA voltage per diode R TA = 125 °C 100 Typical junction capacitance per diode 4.0 V, 1 MHz CJ 13 pF
PARAMETER SYMBOL MB2S MB4S MB6S UNIT
RJA (1) 85 Typical thermal resistance R (2) JA 70 °C/W RJL (1) 20
Notes
(1) On glass epoxy PCB mounted on 0.05" x 0.05" (1.3 mm x 1.3 mm) pads (2) On aluminum substrate PCB with an area of 0.8" x 0.8" (20 mm x 20 mm) mounted on 0.05" x 0.05" (1.3 mm x 1.3 mm) solder pad
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
MB2S-E3/45 0.22 45 100 Tube MB2S-E3/80 0.22 80 3000 13" diameter paper tape and reel Revision: 04-Aug-2020
2
Document Number: 88661 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
