Datasheet S112S01, S112S02, S116S01, S116S02, S212S01, S212S02, S216S01, S216S02 (Sharp)
Manufacturer | Sharp |
Description | SIP Type SSR for Medium Power Control |
Pages / Page | 5 / 1 — S112S01 Series/S116S01 Series. S112S01 Series. SIP Type SSR for Medium … |
File Format / Size | PDF / 83 Kb |
S112S01 Series/S116S01 Series. S112S01 Series. SIP Type SSR for Medium Power Control. S116S01 Series. Features
S112S01 Series/S116S01 Series S112S01 Series SIP Type SSR for Medium Power Control S116S01 Series
Features
Outline Dimensions
(Unit : mm ) 1. Compact, high radiation resin * The metal parts marked* are common to terminal 1 . mold package ❈ Do not allow external connection. 2. RMS ON-state current ( ) : Typical dimensions
S112S01 Series
: 12Arms at TC <= 70˚C 18.5 ± 0.2 A (Model No.) B ( With heat sink) 16.4 ± 0.3
S112S01
12A125VAC
S112S02
φ 0.2
S116S01 Series
3.2 ± 0.2 5.5 ± 0.2 : 16Arms at T ± C <= 60˚C
S116S01
16A125VAC
S116S02
* 3.2 ( With heat sink)
S212S01
12A250VAC 0.3 3. Built-in zero-cross circuit
S212S02
S216S01
16A250VAC 5.0
S216S02 (S112S02 / S212S02 / S116S02 / S216S02 )
0.2 4. High repetitive peak OFF-state voltage A ± ) MAX.
S112S01 / S112S02 / S116S01 / S116S02
19.6 ( 36.0 0.2 B V ❈ + - DRM : 400V 4 - 1.1 ± 0.2
S212S01 / S212S02 / S216S01 / S216S02
4 - 1.25 ± 0.3 MIN. 4 MAX. - 0.8 ± 0.2 VDRM : 600V 4.2 11.2 1 2 3 4 5. Isolation voltage between input and output (V ) iso : 4 000Vrms (5.08) (7.62) (2.54) 0.6 ± 0.1 (1.4) 6. Recognized by UL, file No. E94758 Internal connection diagram
S112S01 / S112S02 S112S01
S116S01 S112S02
S116S02 S212S01
S216S01 S212S02
S216S02 S116S01 / S116S02
7. Approved by CSA, No. 63705 Zero-cross circuit
S112S01 / S112S02 S116S01 / S116S02
1 2 3 4 1 2 3 4 1 Output (Triac T2) 1 Output (Triac T2) ■
Applications
2 Output (Triac T1) 2 Output (Triac T1) 3 Input ( + ) 3 Input ( + ) 1. Copiers, laser beam printers 4 Input ( - ) 4 Input ( - ) 2. Automatic vending machines 3. FA equipment ■
Model line-ups
For 100V For 200V lines lines For phase control
S112S01 S212S01
No built-in zero-cross circuit
S116S01 S216S01 S112S02 S212S02
S116S02 S216S02
“ In the absence of confirmation by device specification sheets, SHARP takes no responsibility for any defects that occur in equipment using any of SHARP's devices, shown in catalogs, data books, etc. Contact SHARP in order to obtain the latest version of the device specification sheets before using any SHARP's device. ”
