Datasheet 74HC595 (Diodes) - 7
ManufacturerDiodes
Description8-bit Shift Register With 8-bit Output Register
Pages / Page11 / 7 — 74HC595. Parameter Measurement Information. TEST. VLOAD. Inputs. VCC. …
File Format / SizePDF / 608 Kb
74HC595. Parameter Measurement Information. TEST. VLOAD. Inputs. VCC. Voltage Waveform. Pulse Duration and Recovery Time
74HC595 Parameter Measurement Information TEST VLOAD Inputs VCC Voltage Waveform Pulse Duration and Recovery Time
From Output RL V Under Test LOAD
TEST VLOAD
tPLH/tPHL Open CL tPLZ/tPZL VCC (see Note A) tPHZ/tPZH GND
Inputs VCC VM CL
VI tr/tf 2.0V VCC 6ns VCC/2 50pF 4.5V VCC 6ns VCC/2 50pF 6.0V VCC 6ns VCC/2 50pF 1/f V MAX CC t Timing V W M Input Vl 0V Input V tSU M VM th VCC 0 V Data V VM Input M 0V MR trec
Voltage Waveform Voltage Waveform Pulse Duration and Recovery Time Set-up and Hold Times
Vl Vl Output VM VM Input V Control M VM 0 V 0 V Output tPZL tPLZ tPLH t V PHL LOAD Waveform 1 VOH VLOAD = VCC VM Output V VM (see Note B) VOL + 10% VOL M VOL tPZH tPHZ Output tPHL tPLH VOH Waveform 2 VOH - 10% VOH VLOAD = GND VM V (see Note B) 0V M Output VM VOL
Voltage Waveform Voltage Waveform Propagation Delay Times Enable and Disable Times Inverting and Non Inverting Outputs
Notes: A. Includes test lead and test apparatus capacitance. B. Output Waveform 1 depends on the internal QN node being low and behaves in this manner based on OE pin. Output Waveform 2 depends on the internal QN node being high and behaves in this manner based on OE pin. C. All pulses are supplied at pulse repetition rate ≤ 10 Hz. D. Inputs are measured separately one transition per measurement. E. tPLH and tPHL are the same as tPD.
Figure 1. Load Circuit and Voltage Waveforms
74HC595 7 of 11 November 2018 Document number: DS35492 Rev. 4 - 2
www.diodes.com
© Diodes Incorporated
