Datasheet MAX4240, MAX4241, MAX4242, MAX4243, MAX4244 (Analog Devices) - 5
Description | Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps |
Pages / Page | 16 / 5 — Single/Dual/Quad, +1.8V/10µA, SOT23,. Beyond-the-Rails Op Amps. … |
File Format / Size | PDF / 2.8 Mb |
Single/Dual/Quad, +1.8V/10µA, SOT23,. Beyond-the-Rails Op Amps. MAX4240–MAX424. ELECTRICAL CHARACTERISTICS. PARAMETER. SYMBOL
Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps MAX4240–MAX424 ELECTRICAL CHARACTERISTICS
(VCC = +1.8V to +5.5V, VEE = 0, VCM = 0, VOUT = VCC / 2, RL = 100kΩ tied to VCC / 2, SHDN = VCC, TA = TMIN to TMAX, unless oth- erwise noted.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX4241ESA 65 MAX4242ESA/MAX4243ESD/ 65 VCC = 1.8V MAX4244ESD MAX4240EUK/MAX424_EUA/ Common-Mode 61 MAX4243EUB Rejection Ratio CMRR dB (Note 4) MAX4241ESA 71 MAX4242ESA/MAX4243ESD/ 71 VCC = 5.0V MAX4244ESD MAX4240EUK/MAX424_EUA/ 67 MAX4243EUB MAX4241ESA 73
4
MAX4242ESA/MAX4243ESD/ Power-Supply 73 PSRR 1.8V ≤ VCC ≤ 5.5V MAX4244ESD dB Rejection Ratio MAX4240EUK/MAX424_EUA/ 71 MAX4243EUB RL = 100kΩ 72 VCC = 1.8V Large-Signal (V A EE + 0.2V) ≤ VOUT ≤ RL = 10kΩ 62 VOL dB Voltage Gain (VCC - 0.2V) RL = 100kΩ 80 VCC = 5.0V RL = 10kΩ 72 RL = 100kΩ 25 VCC = 1.8V Output Voltage Specified as RL = 10kΩ 95 VOH mV Swing High ⎥ VCC - VOH⎥ RL = 100kΩ 30 VCC = 5.0V RL = 10kΩ 145 RL = 100kΩ 20 VCC = 1.8V Output Voltage Specified as RL = 10kΩ 50 VOL mV Swing Low ⎥ VEE - VOL⎥ RL = 100kΩ 25 VCC = 5.0V RL = 10kΩ 75 Output Leakage Current in Shutdown IOUT(SHDN) SHDN = VEE = 0, VCC = 5.5V 100 nA (Notes 2, 5) SHDN Logic Low V (Note 2) IL 0.3 x VCC V
_______________________________________________________________________________________ 5
