Datasheet MAX4240, MAX4241, MAX4242, MAX4243, MAX4244 (Analog Devices) - 7
DescriptionSingle/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps
Pages / Page16 / 7 — Single/Dual/Quad, +1.8V/10µA, SOT23,. Beyond-the-Rails Op Amps. …
Single/Dual/Quad, +1.8V/10µA, SOT23,. Beyond-the-Rails Op Amps. MAX4240–MAX424
Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps MAX4240–MAX424
Single/Dual/Quad, +1.8V/10µA, SOT23, Beyond-the-Rails Op Amps MAX4240–MAX424 ____________________________________Typical Operating Characteristics (continued)
(VCC = +5.0V, VEE = 0, VCM = VCC / 2, VSHDN = VCC, RL = 100kΩ to VCC / 2, TA = +25°C, unless otherwise noted.)
INPUT BIAS CURRENT vs. OUTPUT SWING HIGH OUTPUT SWING LOW COMMON-MODE VOLTAGE (VCC = 5.5V) vs. TEMPERATURE vs. TEMPERATURE
5.0 120 120 VCC = +5.5V RL TO VEE RL TO VCC 100 100 MAX4240/44-07 MAX4240/44-08 MAX4240/44-06b 2.5 (mV) (mV) 80 VCC = +1.8V, RL = 10kΩ 80 CC EE (nA) 0 60 60 V I BIAS CC = +5.5V, RL = 20kΩ VCC = +5.5V, RL = 20kΩ 40 40 VOLTAGE FROM V V -2.5 VOLTAGE FROM V CC = +1.8V, RL = 10kΩ VCC = +5.5V, RL = 100kΩ 20 20 VCC = +5.5V, RL = 100kΩ VCC = +1.8V, RL = 100kΩ VCC = +1.8V, RL = 100kΩ
4
-5.0 0 0 -0.5 0.5 1.5 2.5 3.5 4.5 5.5 -60 -40 -20 0 20 40 60 80 100 -60 -40 -20 0 20 40 60 80 100 VCM (V) TEMPERATURE (°C) TEMPERATURE (°C)
COMMON-MODE REJECTION OPEN-LOOP GAIN vs. OUTPUT SWING LOW OPEN-LOOP GAIN vs. OUTPUT SWING HIGH vs. TEMPERATURE (VCC = +1.8V, RL TIED TO VEE) (VCC = +1.8V, RL TIED TO VEE)
-80 100 100 RL = 100kΩ 90 90 MAX4240/44-09 R MAX4240/44-10 MAX4240/44-11 L = 100kΩ -85 80 80 RL = 10kΩ RL = 10kΩ 70 70 V -90 CC = +1.8V GAIN (dB) 60 GAIN (dB) 60 VCC = +5.5V 50 50 -95 COMMON-MODE REJECTION (dB) 40 40 -100 30 30 -60 -40 -20 0 20 40 60 80 100 0 100 200 300 400 500 0 100 200 300 400 500 TEMPERATURE (°C) ΔVOUT (mV) ΔVOUT (mV)
OPEN-LOOP GAIN vs. OUTPUT SWING LOW OPEN-LOOP GAIN vs. OUTPUT SWING HIGH OPEN-LOOP GAIN (VCC = +5.5V, RL TIED TO VEE) (VCC = +5.5V, RL TIED TO VEE) vs. TEMPERATURE
110 110 110 RL = 100kΩ 100 100 105 RL = 100kΩ MAX4240/44-12 MAX4240/44-13 MAX4240/44-14 VCC = +5.5V, RL = 20kΩ TO VEE 100 90 90 RL = 20kΩ 95 80 80 RL = 20kΩ 90 VCC = +5.5V, RL = 20kΩ TO VCC GAIN (dB) GAIN (dB) 70 70 GAIN (dB) 85 60 60 VCC = +1.8V, RL = 10kΩ TO VEE 80 50 50 75 VCC = +1.8V, RL = 10kΩ TO VCC 40 40 70 0 100 200 300 400 0 100 200 300 400 -60 -40 -20 0 20 40 60 80 100 ΔVOUT (mV) ΔVOUT (mV) TEMPERATURE (°C)
_______________________________________________________________________________________ 7
