Datasheet LT1176, LT1176-5 (Analog Devices) - 2
DescriptionStep-Down Switching Regulator
Pages / Page8 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
File Format / SizePDF / 145 Kb
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT1176/LT1176-5
Input Voltage ...38V ILIM Pin Voltage (Forced) ...5.5V Switch Voltage with Respect to Input Voltage...50V Maximum Operating Ambient Temperature Range Switch Voltage with Respect to Ground Pin LT1176C/LT1176C-5 ... 0°C to 70°C (VSW Negative) (Note 7) ..20V Maximum Operating Junction Temperature Range Feedback Pin Voltage ..–2V, 10V LT1176C/LT1176C-5 ... 0°C to 125°C Shutdown Pin Voltage (Not to Exceed VIN) ...35V Storage Temperature Range .. –65°C to 150°C Status Pin Voltage Lead Temperature (Soldering, 10 sec) ...300°C (Current Must Be Limited to 5mA When Status Pin Switches ON) ..30V *These thermal resistance numbers are for typical mounting technique. Lower thermal resistance can be obtained with large copper lands, thermal glues or heat sinks.
PIN CONFIGURATION
TOP VIEW VIN 1 20 VSW NC 2 19 NC TOP VIEW ILIM 3 18 VC VIN 1 8 VSW GND 4 17 GND ILIM 2 7 VC GND 5 16 GND GND 3 6 STATUS GND 6 15 GND FB/SENSE 4 5 SHUTDOWN GND 7 14 GND NC 8 13 STATUS N8 PACKAGE 8-LEAD PLASTIC DIP FB/SENSE 9 12 SHUTDOWN TJMAX = 125°C, θJA = 90°C/W NC 10 11 NC SW PACKAGE 20-LEAD PLASTIC SOL TJMAX = 125°C, θJA = 50°C/W
LT1176CN8#PBF LT1176CN8 8-Lead Plastic DIP 0°C to 125°C LT1176CN8-5#PBF LT1176CN8-5 8-Lead Plastic DIP 0°C to 125°C LT1176CSW#PBF LT1176CSW#TRPBF LT1176CSW 20-Lead Plastic SOL 0°C to 125°C LT1176CSW-5#PBF LT1176CSW-5#TRPBF LT1176CSW-5 20-Lead Plastic SOL 0°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 11765fb 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Block Diagram Package Description Revision History Package Description
