Datasheet Si2334DS (Vishay) - 2
ManufacturerVishay
DescriptionN-Channel 30 V (D-S) MOSFET
Pages / Page9 / 2 — Si2334DS. SPECIFICATIONS. Parameter. Symbol. Test Conditions. Min. Typ. …
File Format / SizePDF / 190 Kb
Si2334DS. SPECIFICATIONS. Parameter. Symbol. Test Conditions. Min. Typ. Max. Unit. Static. Dynamicb. Drain-Source Body Diode Characteristics
Si2334DS SPECIFICATIONS Parameter Symbol Test Conditions Min Typ Max Unit Static Dynamicb Drain-Source Body Diode Characteristics
Si2334DS
Vishay Siliconix
SPECIFICATIONS
TJ = 25 °C, unless otherwise noted
Parameter Symbol Test Conditions Min. Typ. Max. Unit Static
Drain-Source Breakdown Voltage VDS VGS = 0 V, ID = 250 µA 30 V VDS Temperature Coefficient VDS/TJ 2.8 ID = 250 µA mV/°C VGS(th) Temperature Coefficient VGS(th)/TJ - 0.2 Gate-Source Threshold Voltage VGS(th) VDS = VGS , ID = 250 µA 0.4 1.0 V Gate-Source Leakage IGSS VDS = 0 V, VGS = ± 8 V ± 100 nA VDS = 30 V, VGS = 0 V 1 Zero Gate Voltage Drain Current IDSS µA VDS = 30 V, VGS = 0 V, TJ = 55 °C 10 On-State Drain Currenta I  D(on) VDS 5 V, VGS = 10 V 10 A V  GS 4.5 V, ID = 4.2 A 0.035 0.044 Drain-Source On-State Resistancea RDS(on) V  GS 2.5 V, ID = 4.0 A 0.040 0.050 Forward Transconductancea gfs VDS = 15 V, ID = 4.2 A 27 S
Dynamicb
Input Capacitance Ciss 634 Output Capacitance C V oss DS = 15 V, VGS = 0 V, f = 1 MHz 65 pF Reverse Transfer Capacitance Crss 30 VDS = 15 V, VGS = 4.5 V, ID = 4.2 A 6.5 10 Total Gate Charge Qg 3.7 6 nC Gate-Source Charge Qgs VDS = 15 V, VGS = 2.5 V, ID = 4.2 A 1.2 Gate-Drain Charge Qgd 0.8 Gate Resistance Rg f = 1 MHz 0.5 2.7 5.4 Turn-On Delay Time td(on) 6 12 Rise Time tr VDD = 15 V, RL = 4.4 10 20 I Turn-Off Delay Time td(off) D  3.4 A, VGEN = 4.5 V, Rg = 1 16 24 Fall Time tf 8 16 ns Turn-On Delay Time td(on) 4 8 Rise Time tr VDD = 15 V, RL = 4.4 10 20 I Turn-Off Delay Time td(off) D  3.4 A, VGEN = 8 V, Rg = 1 18 27 Fall Time tf 8 16
Continuous Source-Drain Diode Current IS TC = 25 °C 1.4 A Pulse Diode Forward Current ISM 10 Body Diode Voltage V  SD IS = 3.4 A, VGS 0 V 0.8 1.2 V Body Diode Reverse Recovery Time trr 11 20 ns Body Diode Reverse Recovery Charge Qrr 5 10 nC IF = 3.4 A, dI/dt = 100 A/µs, TJ = 25 °C Reverse Recovery Fall Time ta 7 ns Reverse Recovery Rise Time tb 4 Notes: a. Pulse test; pulse width  300 µs, duty cycle  2 %. b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. www.vishay.com Document Number: 66802 2 S10-1533-Rev. A, 19-Jul-10
