Datasheet SFH6156 (Vishay) - 2
ManufacturerVishay
DescriptionOptocoupler, Phototransistor Output, High Reliability, 5300 V RMS
Pages / Page9 / 2 — SFH6156. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 174 Kb
SFH6156. ABSOLUTE MAXIMUM RATINGS. PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. INPUT. OUTPUT. COUPLER. Notes
SFH6156 ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL VALUE UNIT INPUT OUTPUT COUPLER Notes
SFH6156
(Tamb = 25 °C, unless otherwise specified)
Reverse voltage VR 6 V DC forward current IF 60 mA Surge forward current tp ≤ 10 μs IFSM 2.5 A
OUTPUT
Collector emitter voltage VCEO 70 V Emitter collector voltage VECO 7 V IC 50 mA Collector current tp ≤ 1 ms IC 100 mA
COUPLER
Storage temperature range Tstg -55 to +150 °C Ambient temperature range Tamb -55 to +100 °C Soldering temperature (1) max. 10 s Tsld 260 °C
Notes
• Stresses in excess of the absolute maximum ratings can cause permanent damage to the device. Functional operation of the device is not implied at these or any other conditions in excess of those given in the operational sections of this document. Exposure to absolute maximum ratings for extended periods of the time can adversely affect reliability (2) Refer to reflow profile for soldering conditions for surface mounted devices (SMD) 200 150 Phototransistor 100 50 Diode - Power Dissipation (mW) tot P 0 0 25 50 75 100 125 150 18483 T - Ambient Temperature (°C) amb Fig. 1 - Permissible Power Dissipation vs. Ambient Temperature Rev. 3.0, 15-Mar-2023
2
Document Number: 83671 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
