Datasheet VCNL36828P (Vishay) - 6
ManufacturerVishay
DescriptionA Small Package Proximity Sensor With a VCSEL, Low Idle Current, I 2C Interface, and Smart Dual Slave Address
Pages / Page20 / 6 — VCNL36828P. PARAMETER TIMING INFORMATION
File Format / SizePDF / 287 Kb
VCNL36828P PARAMETER TIMING INFORMATION
VCNL36828P
I2C BUS CLOCK (SCL) I2C BUS DATA SA7 SA6 SA5 SA4 SA3 SA2 SA1 W SA6 SA5 SA4 SA3 SA2 SA1 SA0 SA7 (SDA) Start by ACK by ACK by master VCNL36828P VCNL36828P I2C bus slave address byte Command code I2C BUS CLOCK (SCL) I2C BUS DATA SA7 SA6 SA5 SA4 SA3 SA2 SA1 SA0 SA7 SA6 SA5 SA4 SA3 SA2 SA1 SA0 (SDA) ACK by ACK by Stop by VCNL36828P VCNL36828P master Data byte low Data byte high Fig. 2 - I2C Bus Timing for Sending Word Command Format I2C BUS CLOCK (SCL) I2C BUS DATA SA7 SA6 SA5 SA4 SA3 SA2 SA1 W SA7 SA6 SA5 SA4 SA3 SA2 SA1 SA0 (SDA) Start by ACK by ACK by master VCNL36828P VCNL36828P I2C bus slave address byte Command code I2C BUS CLOCK (SCL) I2C BUS DATA SA7 SA6 SA5 SA4 SA3 SA2 SA1 R SA7 SA6 SA5 SA4 SA3 SA2 SA1 SA0 (SDA) Start by ACK by ACK by master VCNL36828P master I2C bus slave address byte Data byte low I2C BUS CLOCK (SCL) I2C BUS DATA SA7 SA6 SA5 SA4 SA3 SA2 SA1 SA0 (SDA) NACK by Stop by master master Data byte high Fig. 3 - I2C Bus Timing for Receiving Word Command Format Rev. 1.2, 16-Nov-2023
6
Document Number: 80306 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
