Datasheet TSB711, TSB711A TSB712, TSB712A (STMicroelectronics) - 2
Manufacturer | STMicroelectronics |
Description | Precision Rail-To-Rail Input/Output 36 V, 6 MHz Op Amps |
Pages / Page | 32 / 2 — TSB711, TSB711A, TSB712, TSB712A. Pin description. Figure 1. TSB711 pin … |
File Format / Size | PDF / 4.3 Mb |
TSB711, TSB711A, TSB712, TSB712A. Pin description. Figure 1. TSB711 pin connections (top view)
TSB711, TSB711A, TSB712, TSB712A Pin description 1 Pin description Figure 1. TSB711 pin connections (top view)
OUT VCC+ VCC- IN+ IN- SOT23-5
Table 1. TSB711 pin description (SOT23-5) Pin n° Pin name Description
1 OUT Output channel 2 VCC- Negative supply voltage 3 IN1+ Non-inverting input channel 4 IN- Inverting input channel 5 VCC+ Positive supply voltage
Figure 2. TSB712 pin connections (top view)
OUT1 VCC+ IN1- OUT2 IN1+ IN2- VCC- IN2+ MiniSO8/SO8
Table 2. TSB712 pin description (miniSO8/SO8) Pin n° Pin name Description
1 OUT1 Output channel 1 2 IN1- Inverting input channel 1 3 IN1+ Non-inverting input channel 1 4 VCC- Negative supply voltage 5 IN2+ Non-inverting input channel 2 6 IN2- Inverting input channel 2 7 OUT2 Output channel 2 8 VCC+ Positive supply voltage
DS12487
Rev 7 page 2/32
Document Outline TSB711, TSB711A, TSB712, TSB712A 1 Pin description 2 Absolute maximum ratings and operating conditions 3 Electrical characteristics 4 Typical performance characteristics 5 Application information 5.1 Operating voltages 5.2 Input pin voltage range 5.3 Rail-to-rail input stage 5.4 Input offset voltage drift over the temperature 5.5 Long term input offset voltage drift 5.6 EMI rejection 5.7 Maximum power dissipation 5.8 Capacitive load and stability 5.9 PCB layout recommendations 5.10 Decoupling capacitor 6 Typical applications 6.1 Low-side current sensing 7 Package information 7.1 SOT23-5 package information 7.2 MiniSO8 package information 7.3 SO8 package information 8 Ordering information Revision history
