Datasheet MAX4460, MAX4461, MAX4462 (Analog Devices) - 6
DescriptionSOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers
Pages / Page20 / 6 — SOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers. …
File Format / SizePDF / 436 Kb
SOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers. ELECTRICAL CHARACTERISTICS—MAX4462 (continued)
SOT23, 3V/5V, Single-Supply, Rail-to-Rail Instrumentation Amplifiers ELECTRICAL CHARACTERISTICS—MAX4462 (continued)
(VDD = 5V, VSS = 0V, VCM = VREF = VDD/2, RL = 100kΩ to VDD/2,
TA = +25°C
, unless otherwise noted. VDIFF = VIN+ - VIN- = -100mV to +100mV for G = 1 and G = 10, -20mV to +20mV for G = 100.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Maximum Capacitive Load CL No sustained oscillations 100 pF G = 1V/V, MAX4462U 2500 -3dB Bandwidth BW-3dB CL = 100pF kHz G = 10V/V, MAX4462T 250 G = 100V/V, MAX4462H 25 Gain-Bandwidth Product GBWP CL = 100pF 2.5 MHz G = 1V/V, MAX4462U 0.5 Slew Rate SR CL = 100pF G = 10V/V, MAX4462T 0.5 V/µs G = 100V/V, MAX4462H 0.25 G = 1V/V, MAX4462U 15 CL = 100pF, Settling Time tS within 0.1% of G = 10V/V, MAX4462T 75 µs final value G = 100V/V, MAX4462H 250
TA = TMIN to TMAX
, unless otherwise noted. VDIFF = VIN+ - VIN- = -100mV to +100mV for G = 1 and G = 10, -20mV to +20mV for G = 100.) (Note 5)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS MAX4460/MAX4461/MAX4462
Supply Voltage VDD Guaranteed by PSRR test 2.85 5.25 V VDD = 5V, VDIFF = 0V 1.4 Supply Current mA VDD = 3V, VDIFF = 0V 1.15 TA = 0°C to +85°C ±500 MAX4462_ESA TA = -40°C to +85°C ±750 Input Offset Voltage (Note 1) VOS µV MAX4462_EUT/ TA = 0°C to +85°C ±1100 MAX4462_ETT TA = -40°C to +85°C ±1300 Input Offset Voltage Drift TCVOS (Note 1) 1.5 µV/°C V V - Input Common-Mode Range V SS - DD CM Guaranteed by input CMRR test V 0.1 1.85 V V - REF Input Range Guaranteed by REF rejection test SS + DD V 0.1 1.85 Input Common-Mode CMRR VCM = (VSS – 0.1V) to (VDD - 1.85V) 80 dB Rejection Ratio REF Input Rejection Ratio VCM = (VSS + 0.1V) to (VDD - 1.85V) 75 dB Power-Supply Rejection Ratio PSRR VDD = 2.85V to 5.25V 75 dB Input Bias Current IB (Note 2) 100 pA
6 _______________________________________________________________________________________
