Datasheet PA05 (Apex) - 9
ManufacturerApex
DescriptionPower Operational Amplifier
Pages / Page15 / 9 — PA05. Figure 8: Slew Rate vs. Comp. Figure 9: Output Voltage Swing. …
File Format / SizePDF / 829 Kb
PA05. Figure 8: Slew Rate vs. Comp. Figure 9: Output Voltage Swing. Figure 10: Common Mode Rejection. Figure 11: Pulse Response
PA05 Figure 8: Slew Rate vs Comp Figure 9: Output Voltage Swing Figure 10: Common Mode Rejection Figure 11: Pulse Response
PA05 Figure 8: Slew Rate vs. Comp Figure 9: Output Voltage Swing
100 12 (V) OUT V 10 - ) 80 S V /μs (V 8 60 V = V S B 6 ^ůĞǁZĂƚĞ͕^Z 40 4 + 5V V = V S B Voltage Drop From Supply, 20 2 100 200 300 400 500 0 5 10 15 20 25 30 džƚ͘ŽŵƉĞŶƐĂƟŽŶĂƉĂĐŝƚŽƌ͕C (pF) Output Current, I (A) C OUT
100 7.5 A = +1 C = 470pF V C 5 80 (V) OUT 2.5 V 60 0 40 -2.5 Output Voltage, 20 -5 ŽŵŵŽŶDŽĚĞZĞũĞĐƟŽŶ͕DZ;ĚͿ 0 -7.5 10 100 1k 10k 100k 1M 0 5 10 15 20 25 30 Frequency, F (Hz) Time, t (μs) PA05U Rev O 9 Document Outline PA05 Features Applications Description Figure 1: Equivalent Schematic Typical Connection Figure 2: Typical Connections Pinout and Description Table Figure 3: External Connections Specifications Absolute Maximum Ratings Input Gain Output Power Supply Thermal Typical Performance Graphs SAFE OPERATING AREA (SOA) 1. The current handling capability of the MOSFET geometry and the wire bonds. 2. The junction temperature of the output MOSFETs. Figure 16: SOA General Typical Application Figure 17: Typical Application Phase Compensation Current Limit Figure 18: Current Limit Shutdown Operation Figure 19: Shutdown Operation Boost Operation Compensation Package Design Package Style CR
