Datasheet MAX5035 (Maxim) - 6
ManufacturerMaxim
Description1A, 76V, High-Efficiency MAXPower Step-Down DC-DC Converter
Pages / Page17 / 6 — 1A, 76V, High-Efficiency MAXPower Step-Down DC-DC Converter. Typical …
File Format / SizePDF / 553 Kb
1A, 76V, High-Efficiency MAXPower Step-Down DC-DC Converter. Typical Operating Characteristics (continued)
1A, 76V, High-Efficiency MAXPower Step-Down DC-DC Converter Typical Operating Characteristics (continued)
MAX5035
(VIN = 12V, VON/OFF = 12V, TA = -40°C to +125°C, unless otherwise noted. Typical values are at TA = +25°C. See the Typical Application Circuit, if applicable.)
EFFICIENCY vs. LOAD CURRENT EFFICIENCY vs. LOAD CURRENT EFFICIENCY vs. LOAD CURRENT (MAX5035AASA, VOUT = 3.3V) (MAX5035DASA, VOUT = 5V) (MAX5035DASA, VOUT = 12V)
100 100 100 90 90 90 MAX5035 toc07 80 MAX5035 toc08 80 MAX5035 toc09 80 70 70 70 VIN = 15V 60 60 V 60 IN = 7.5V VIN = 7.5V VIN = 24V 50 50 V 50 IN = 12V VIN = 12V VIN = 48V 40 40 40 EFFICIENCY (%) VIN = 24V EFFICIENCY (%) VIN = 24V EFFICIENCY (%) V 30 30 30 IN = 76V VIN = 48V VIN = 48V 20 20 20 VIN = 76V VIN = 76V 10 10 10 0 0 0 0 200 400 600 800 1000 0 200 400 600 800 1000 0 200 400 600 800 1000 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA)
OUTPUT CURRENT LIMIT OUTPUT CURRENT LIMIT QUIESCENT SUPPLY CURRENT vs. TEMPERATURE vs. INPUT VOLTAGE vs. TEMPERATURE
2.0 2.0 350 MAX5035 toc10 MAX5035 toc11 1.7 µA) MAX5035 toc12 320 1.5 1.4 290 1.0 1.1 260 OUTPUT CURRENT LIMIT (A) 0.5 OUTPUT CURRENT LIMIT (A) MAX5035DASA 0.8 MAX5035DASA 230 QUIESCENT SUPPLY CURRENT ( VOUT = 5V VOUT = 5V 5% DROP IN VOUT 5% DROP IN VOUT 0 0.5 200 -50 -25 0 25 50 75 100 125 150 5 20 35 50 65 80 -50 -25 0 25 50 75 100 125 150 TEMPERATURE (°C) INPUT VOLTAGE (V) TEMPERATURE (°C)
QUIESCENT SUPPLY CURRENT SHUTDOWN CURRENT vs. INPUT VOLTAGE vs. TEMPERATURE SHUTDOWN CURRENT vs. INPUT VOLTAGE
350 25 20 µA) MAX5035 toc13 320 MAX5035 toc14 20 MAX5035 toc15 16 µA) µA) 290 15 12 260 10 8 SHUTDOWN CURRENT ( SHUTDOWN CURRENT ( 230 5 4 QUIESCENT SUPPLY CURRENT ( 200 0 0 6 16 26 36 46 56 66 76 -50 -25 0 25 50 75 100 125 150 6 16 26 36 46 56 66 76 INPUT VOLTAGE (V) TEMPERATURE (°C) INPUT VOLTAGE (V) 6 Maxim Integrated
