Datasheet FS (Spectra Symbol)
ManufacturerSpectra Symbol
DescriptionFlex Sensor
Pages / Page2 / 1 — Features. -. Angle. Displacement. Measurement. -. Bends. and. Flexes. …
File Format / SizePDF / 449 Kb
Features. -. Angle. Displacement. Measurement. -. Bends. and. Flexes. physically. with. motion. device. -. Possible. Uses. -. Robotics. -. Gaming. (Virtual
Datasheet FS Spectra Symbol
Features - Angle Displacement Measurement - Bends and Flexes physically with motion device - Possible Uses - Robotics - Gaming (Virtual Motion) - Medical Devices - Computer Peripherals - Musical Instruments - Physical Therapy - Simple Construction - Low Profile Mechanical Specifications Electrical Specifications -Life Cycle: >1 million -Flat Resistance: 10K Ohms ±30% -Height: 0.43mm (0.017") -Bend Resistance: minimum 2 times greater than -Temperature Range: -35°C to +80°C the flat resistance at 180° pinch bend (see "How it Works" below) -Power Rating : 0.5 Watts continuous; 1 Watt Peak Dimensional Diagram - Stock Flex Sensor PART LENGTH 112.24 [4.419] ACTIVE LENGTH 6.35 [0.250] 95.25 [3.750] How to Order - Stock Flex Sensor FS L 0095 103 ST Series Model Active Length Resistance Connectors FS = Flex Sensor L = Linear 0095 = 95.25mm 103 = 10 KOhms ST = Solder Tab How It Works Conductive Inks This Side Flat Resistance = 7,000 to 13,000 Ohms Bend Direction 180° Pinch Bend = Minimum 2x of Flat Resistance Value spectrasymbol.com v.2014 Rev A - Page 1 (888) 795-2283
