Datasheet BDX42, BDX43, BDX44 (Philips) - 6
ManufacturerPhilips
DescriptionNPN Darlington Transistors
Pages / Page8 / 6 — PACKAGE OUTLINE. Plastic single-ended leaded (through hole) package; …
File Format / SizePDF / 56 Kb
PACKAGE OUTLINE. Plastic single-ended leaded (through hole) package; mountable to heatsink, 1 mounting hole; 3 leads. SOT32
PACKAGE OUTLINE Plastic single-ended leaded (through hole) package; mountable to heatsink, 1 mounting hole; 3 leads SOT32
Philips Semiconductors Product specification NPN Darlington transistors BDX42; BDX43; BDX44
E A P1 P D L1 L
1 2 3
b e w M c p 1 Q e 0 2.5 5 mm scale
DIMENSIONS (mm are the original dimensions) L UNIT A b 1(1) p c D E e e1 L Q P P w 1 max
2.7 0.88 0.60 11.1 7.8 16.5 1.5 3.2 3.9 mm 4.58 2.29 2.54 0.254 2.3 0.65 0.45 10.5 7.2 15.3 0.9 3.0 3.6
Note
1. Terminal dimensions within this zone are uncontrolled to allow for flow of plastic and terminal irregularities.
REFERENCES OUTLINE EUROPEAN ISSUE DATE VERSION PROJECTION IEC JEDEC EIAJ
SOT32 TO-126 97-03-04 1997 Jul 02 6 Document Outline FEATURES APPLICATIONS DESCRIPTION PINNING QUICK REFERENCE DATA LIMITING VALUES THERMAL CHARACTERISTICS CHARACTERISTICS PACKAGE OUTLINE SOT32 DEFINITIONS
