Datasheet MC74AC132, MC74ACT132 (ON Semiconductor) - 3
ManufacturerON Semiconductor
DescriptionQuad 2-Input NAND Schmitt Trigger
Pages / Page8 / 3 — MC74AC132, MC74ACT132. DC CHARACTERISTICS. 74AC. A =. Symbol. Parameter. …
File Format / SizePDF / 201 Kb
MC74AC132, MC74ACT132. DC CHARACTERISTICS. 74AC. A =. Symbol. Parameter. −40. (V). TA = +25. C to. Unit. Conditions. +85. Typ. Guaranteed Limits
MC74AC132, MC74ACT132 DC CHARACTERISTICS 74AC A = Symbol Parameter −40 (V) TA = +25 C to Unit Conditions +85 Typ Guaranteed Limits
MC74AC132, MC74ACT132 DC CHARACTERISTICS 74AC 74AC T V A = Symbol Parameter CC −40 (V) TA = +25
C
C Typ Guaranteed Limits
VOH Minimum High Level 3.0 2.99 2.9 2.9 IOUT = −50 mA Output Voltage 4.5 4.49 4.4 4.4 V 5.5 5.49 5.4 5.4 *VIN = VIL or VIH 3.0 − 2.56 2.46 −12 mA V 4.5 − 3.86 3.76 IOH −24 mA 5.5 − 4.86 4.76 −24 mA VOL Maximum Low Level 3.0 0.002 0.1 0.1 IOUT = 50 mA Output Voltage 4.5 0.001 0.1 0.1 V 5.5 0.001 0.1 0.1 *VIN = VIL or VIH 3.0 − 0.36 0.44 12 mA V 4.5 − 0.36 0.44 IOL 24 mA 5.5 − 0.36 0.44 24 mA IIN Maximum Input Leakage Current 5.5 − ±0.1 ±1.0 mA VI = VCC, GND IOLD †Minimum Dynamic 5.5 − − 75 mA VOLD = 1.65 V Max Output Current IOHD 5.5 − − −75 mA VOHD = 3.85 V Min ICC Maximum Quiescent − Supply Current 5.5 4.0 40 mA VIN = VCC or GND Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. *All outputs loaded; thresholds on input associated with output under test. †Maximum test duration 2.0 ms, one output loaded at a time. NOTE: IIN and ICC @ 3.0 V are guaranteed to be less than or equal to the respective limit @ 5.5 V VCC.
AC CHARACTERISTICS 74AC 74AC T V T A = −40
C Symbol Parameter CC* A = +25
C to +85 (V)
C Unit CL = 50 pF CL = 50 pF Min Typ Max Min Max
3.3 2.0 − 13.0 1.5 14.0 tPLH Propagation Delay ns 5.0 2.0 − 9.0 1.5 10.0 3.3 2.0 − 13.5 1.5 15.0 tPHL Propagation Delay ns 5.0 2.0 − 9.0 1.5 10.0 *Voltage Range 3.3 V is 3.3 V ±0.3 V. Voltage Range 5.0 V is 5.0 V ±0.5 V.
www.onsemi.com 3
