Datasheet SS52, SS54, SS56, SS58, SS510, SS315, SS520 (Nanjing International Group)
ManufacturerNanjing International Group
Description5.0 Amp Surface Mount Schottky Barrier Rectifiers
Pages / Page2 / 1 — FEATURES. DO-214AA(SMB). MECHANICAL DATA. UNITS. NOTES:
File Format / SizePDF / 400 Kb
Datasheet SS52, SS54, SS56, SS58, SS510, SS315, SS520 Nanjing International Group
SS52 THRU SS520 5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 20 to200 Volts CURRENT
FEATURES
5.0 Ampere * Low forward voltage drop * High current capability
DO-214AA(SMB)
* High reliability * High surge current capability * Epitaxial construction .083(2.11) .155(3.94)
MECHANICAL DATA
.075(1.91) .130(3.30) * Case: Molded plastic .185(4.70) .160(4.06) * Epoxy: UL 94V-0 rate flame retardant .012(0.31) * Lead: Axial leads, solderable per MIL-STD-202, .006(0.15) method 208 guranteed .111(2.84) * Polarity: Color band denotes cathode end .091(2.33) * Mounting position: Any .050(1.27) .008 * Weight: 0.093 grams MAX. .030(0.76) (.203) * Both normal and Pb free product are available: .220(5.59) .200(5.08) * Normal:80~95%Sn,5~20%Pb * Pb free:99 Sn above can meet Rohs enviroment substance Dimensions in inches and (millimeters) directive request MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SS52 SS54 SS56 SS58 SS510 SS315 SS52
UNITS
0 Maximum Recurrent Peak Reverse Voltage 20 40 60 80 100 150 200 V Maximum RMS Voltage 14 28 42 56 70 105 140 V Maximum DC Blocking Voltage 20 40 60 80 100 150 200 V Maximum Average Forward Rectified Current See Fig. 1 5.0 V Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) 150 A Maximum Instantaneous Forward Voltage at 5.0A 0.55 0.70 0.85 V Maximum DC Reverse Current Ta=25 C 0.2 mA at Rated DC Blocking Voltage Ta=100 C 20 mA Typical Junction Capacitance (Note1) 380 pF Typical Thermal Resistance RqJA (Note 2) 10 C /W Operating Temperature Range Tj -65 +125 -65 +150 C Storage Temperature Range TSTG -65 +150 C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Ambient. www.dgnjdz.com Document Outline �¶�± 1 �¶�± 2
