Datasheet NCV7329 (ON Semiconductor) - 4
ManufacturerON Semiconductor
DescriptionStand-Alone LIN Transceiver
Pages / Page14 / 4 — NCV7329. ELECTRICAL CHARACTERISTICS. Definitions. Table 4. DC …
File Format / SizePDF / 381 Kb
NCV7329. ELECTRICAL CHARACTERISTICS. Definitions. Table 4. DC CHARACTERISTICS. Symbol. Parameter. Conditions. Min. Typ. Max. Unit
NCV7329 ELECTRICAL CHARACTERISTICS Definitions Table 4 DC CHARACTERISTICS Symbol Parameter Conditions Min Typ Max Unit
link to page 5
All voltages are referenced to GND (pin 5) unless otherwise specified. Positive currents flow into the IC. Sinking current means the current is flowing into the pin; sourcing current means the current is flowing out of the pin.
(VBB = 5 V to 18 V; TJ = −40°C to +150°C; Typical values are given at VBB = 12 V and TJ = 25°C Bus Load = 500 W (VBB to LIN); unless otherwise specified.)
Symbol Parameter Conditions Min. Typ. Max. Unit SUPPY PIN (VBB)
VBB Battery Supply 5 18 V IBB Battery Supply Current Normal Mode; LIN recessive 0.2 0.55 1.2 mA IBB Battery Supply Current Normal Mode; TxD = Low, LIN 2 3.9 6.5 mA Dominant IBB Battery Supply Current Sleep and Standby Mode; 6 10 mA LIN recessive; VLIN = VBB; TJ<85°C IBB Battery Supply Current Sleep and Standby Mode; 6 15 mA LIN recessive; VLIN = VBB
POR AND VBB MONITOR
PORH_VBB Power−on Reset; High Level on VBB VBB Rising 2.7 3.5 4.4 V PORL_VBB Power−on Reset; Low Level on VBB VBB Falling 1.3 2.1 2.7 V MONH_VBB Battery Monitoring High Level VBB Rising 3.2 4.2 5.0 V MONL_VBB Battery Monitoring Low Level VBB Falling 3.0 4.0 4.8 V
TRANSMITTER DATA INPUT (PIN TxD)
VIL_TxD Low Level Input Voltage −0.3 +0.8 V VIH_TxD High Level Input Voltage 2 7 V RPD_TxD Pull−down Resistor on TxD Pin 50 125 325 kW
RECEIVER DATA OUTPUT (PIN RxD)
IOL_RxD Low Level Output Current VRXD = 0.4 V 2 mA IOH_RxD High Level Output Current −5 +5 mA
ENABLE INPUT (PIN EN)
VIL_EN Low Level Input Voltage −0.3 +0.8 V VIH_EN High Level Input Voltage 2 7 V RPD_EN Pull−down Resistor to Ground 100 250 650 kW
LIN BUS LINE (PIN LIN)
VBUS_DOM Bus Voltage for Dominant State 0.4 VBB VBUS_REC Bus Voltage for Recessive State 0.6 VBB VREC_DOM Receiver Threshold LIN Bus Recessive − Dominant 0.4 0.6 VBB VREC_REC Receiver Threshold LIN Bus Dominant – Recessive 0.4 0.6 VBB VREC_CNT Receiver Centre Voltage (VREC_DOM + VREC_REC) / 2 0.475 0.500 0.525 VBB VREC_HYS Receiver Hysteresis (VREC_REC − VREC_DOM) 0.050 0.175 VBB VLIN_DOM Dominant Output Voltage Normal mode; VBB = 7 V 1.2 V Normal mode; VBB = 18 V 2.0 V IBUS_no_GND Communication not Affected VBB = GND = 12 V; 0 < VLIN < 18 V −1 +1 mA IBUS_no_VBB LIN Bus Remains Operational VBB = GND = 0 V; 0 < VLIN < 18 V 5 mA 8. Values based on design and characterization. Not tested in production.
www.onsemi.com 4
