Datasheet MC145026, MC145027, MC145028 (NXP) - 4
ManufacturerNXP
DescriptionEncoder and Decoder Pairs CMOS
Pages / Page20 / 4 — Electrical Specifications. Figure 4. MC145028 Decoder Block Diagram. …
File Format / SizePDF / 810 Kb
Electrical Specifications. Figure 4. MC145028 Decoder Block Diagram. Table 1. Maximum Ratings*. Ratings. Symbol. Value. Unit
Electrical Specifications Figure 4 MC145028 Decoder Block Diagram Table 1 Maximum Ratings* Ratings Symbol Value Unit
CONTROL 11 VT LOGIC SEQUENCER CIRCUIT 9 8 7 6 5 4 3 2 1 1 A1 9-BIT 2 SHIFT A2 REGISTER 3 A3 4 A4 5 DATA 9 A5 D EXTRACTOR in 15 A6 C V 1 C R 2 DD = PIN 16 14 7 1 6 VSS = PIN 8 A7 10 13 A8 R2 12 A9
Figure 4. MC145028 Decoder Block Diagram 2 Electrical Specifications Table 1. Maximum Ratings*
(Voltages Referenced to VSS)
DC Supply Voltage VDD - 0.5 to + 18 V DC Input Voltage Vin - 0.5 to VDD + 0.5 V DC Output Voltage Vout - 0.5 to VDD + 0.5 V DC Input Current, per Pin I ± in 10 mA DC Output Current, per Pin I ± out 10 mA Power Dissipation, per Package PD 500 mW Storage Temperature Tstg - 65 to + 150 °C Lead Temperature, 1 mm from Case for 10 Seconds TL 260 °C * Maximum Ratings are those values beyond which damage to the device may occur. Functional operation should be restricted to the limits in the Electrical Characteristics tables or Pin Descriptions section. This device contains protection circuitry to guard against damage due to high static voltages or electric fields. However, precautions must be taken to avoid applications of any voltage higher than maximum rated voltages to this high-impedance circuit. For proper operation, Vin and Vout should be constrained to the range VSS ≤ (Vin or Vout) ≤ VDD.
MC145026, MC145027, MC145028 Technical Data, Rev. 4
4 Freescale Semiconductor Document Outline 1 Introduction 2 Electrical Specifications 3 Operating Characteristics 3.1 MC145026 3.2 MC145027 3.3 MC145028 4 Pin Descriptions 4.1 MC145026 Encoder 4.2 MC145027 and MC145028 Decoders 5 MC145027 and MC145028 Timing 6 Package Dimensions
