Datasheet TDA8360; TDA8361; TDA8362 (Philips) - 2
ManufacturerPhilips
DescriptionIntegrated PAL and PAL/NTSC TV processors
Pages / Page39 / 2 — Philips Semiconductors. Objective specification. Integrated PAL and …
File Format / SizePDF / 243 Kb
Philips Semiconductors. Objective specification. Integrated PAL and PAL/NTSC TV. TDA8360; TDA8361; TDA8362. processors. FEATURES
Philips Semiconductors Objective specification Integrated PAL and PAL/NTSC TV TDA8360; TDA8361; TDA8362 processors FEATURES
Philips Semiconductors Objective specification Integrated PAL and PAL/NTSC TV TDA8360; TDA8361; TDA8362 processors FEATURES Additional features GENERAL DESCRIPTION Available in TDA8360, TDA8361
TDA8360 The TDA8360, TDA8361 and
and TDA8362
• TDA8362 are single-chip TV Alignment-free PAL colour decoder • processors which contain nearly all Vision IF amplifier with high for all PAL standards, including small signal functions that are sensitivity and good differential PAL-N and PAL-M. required for a colour television gain and phase receiver. For a complete receiver the • Multistandard FM sound TDA8361 following circuits need to be added: demodulator (4.5 MHz to 6.5 MHz) • PAL/NTSC colour decoder with a base-band delay line (TDA4661), • Integrated chrominance trap and automatic search system a tuner and output stages for audio, bandpass filters (automatically • video and horizontal and vertical Source selection for external calibrated) deflection. audio/video (A/V) inputs (separate • Integrated luminance delay line Y/C signals can also be applied). Because of the different functional • RGB control circuit with linear RGB contents of the ICs the set maker can inputs and fast blanking TDA8362 make the optimum choice depending • on the requirements for the receiver. Horizontal synchronization with two • Multistandard vision IF circuit control loops and alignment-free (positive and negative modulation) The TDA8360 is intended for simple horizontal oscillator without • PAL/NTSC colour decoder with PAL receivers (all PAL standards, external components automatic search system including PAL-N and PAL-M are • possible). Vertical count-down circuit • Source selection for external (50/60 Hz) and vertical preamplifier A/V inputs (separate Y/C signals The TDA8361 contains a PAL/NTSC • Low dissipation (700 mW) can also be applied) decoder and has an A/V switch. • Small amount of peripheral • Easy interfacing with the TDA8395 For real multistandard applications components compared with (SECAM decoder) for the TDA8362 is available. In addition competition ICs multistandard applications. to the extra functions which are • Only one adjustment (vision IF available in the TDA8361, the demodulator) TDA8362 can handle signals with • positive modulation and it supplies The supply voltage for the ICs is the signals which are required for the 8 V. They are mounted in a shrink SECAM decoder TDA8395. DIL envelope with 52 pins and are pin compatible.
ORDERING INFORMATION EXTENDED TYPE PACKAGE NUMBER PINS PIN POSITION MATERIAL CODE
TDA8360 52 shrink DIL plastic SOT247AG TDA8361 52 shrink DIL plastic SOT247AG TDA8362 52 shrink DIL plastic SOT247AG March 1994 2
