Datasheet DP1211, DP1311 (Tegam)
ManufacturerTegam
DescriptionDekapot Coaxial-Dial Decade Potentiometer
Pages / Page2 / 1 — Models DP1211/DP1311. R E S I S T A N C E S T A N D A R D S & I N S T …
File Format / SizePDF / 196 Kb
Models DP1211/DP1311. R E S I S T A N C E S T A N D A R D S & I N S T R U M E N T S. Dekapot Coaxial-Dial
Datasheet DP1211, DP1311 Tegam
Models DP1211/DP1311 R E S I S T A N C E S T A N D A R D S & I N S T R U M E N T S Dekapot Coaxial-Dial
• Kelvin-Varley voltage divider • Panel-mounting area from
27.1 to 45.2 cm 2 These Dekapot potentiometers are space. Convenient in-line reading is • Precision resistors throughout precision decade resistive voltage provided by the TEGAM Dekadial • Solid silver-alloy switch contacts dividers featuring the accuracy, high coaxial dial. resolution and constant input The DP1211 offers two decades plus impedance of the Kelvin-Varley circuit. a 100 division potentiometer. The They provide known voltage and DP1311 offers three decades plus a 100
C
current ratios for meter calibration, division potentiometer. linearity checking, ratio measuring, Exceptional stability and reliability synchro testing, computer are assured by the use of precision standardization, and many other DC resistive elements. The ceramic switch and audio frequency applications. decks are silicone-treated to improve The stacked dial configuration insulation resistance, and the multiple conserves space without sacrificing switch contacts are of solid silver-alloy operating ease. Each unit occupies less for long life and low contact resistance. than 45.2 square centimeters of panel ® Prices and specifications subject to change without notice. YOUR GLOBAL SOURCE FOR TEST AND MEASUREMENT SOLUTIONS
